From GH200 to x86 + RTX PRO 6000: Expanding NVIDIA Aerial Deployment Options
After successfully completing our NVIDIA Aerial experiments on the GH200 platform, our lab decided to further explore whether Aerial could also run on an idle RTX PRO 6000 system. The test turned out to be successful. The following code includes the modifications we made during the adaptation process, which we would like to share as a reference for the community.
cubb_scripts/install/versions.sh
SCRIPT_DIR="$(dirname "$(readlink -f "${BASH_SOURCE[0]:-$0}")")"
# When run directly, PLATFORM_ID is not set; compute it from DMI so we can show_versions
if [[ -z "${PLATFORM_ID:-}" ]]; then
    DMI_PATH="${DMI_PATH:-/sys/devices/virtual/dmi/id}"
    _read_dmi() { cat "$DMI_PATH/$1" 2>/dev/null | tr ' ' '_' | tr -s '_' || echo "unknown"; }
    _vb="$(_read_dmi board_vendor)_$(_read_dmi product_family)_$(_read_dmi product_name)_$(_read_dmi board_name)"
    case "$_vb" in
        #There are multiple variants of the Supermicro ARS-111GL-NHR server. Map them to the same platform ID.
        Supermicro_Family_Super_Server_G1SMH-G)  PLATFORM_ID="Supermicro_ARS-111GL-NHR" ;;
        Supermicro_Family_ARS-111GL-NHR_G1SMH-G) PLATFORM_ID="Supermicro_ARS-111GL-NHR" ;;
        NVIDIA_DGX_Spark_NVIDIA_DGX_Spark_P4242) PLATFORM_ID="NVIDIA_DGX_Spark_P4242" ;;
        ASUSTeK_COMPUTER_INC._To_be_filled_by_O.E.M._System_Product_Name_Pro_WS_W790-ACE)
        PLATFORM_ID="ASUS_Pro_WS_W790_ACE"
        *) PLATFORM_ID="$_vb" ;;
    esac
    VERBOSE_PLATFORM_ID="$_vb"
fi
# Default platform if not specified (PLATFORM_ID from includes.sh when sourced, or from DMI above when run directly)
PLATFORM="${PLATFORM:-$PLATFORM_ID}"
# Platform-specific versions
case "$PLATFORM" in
    "NVIDIA_DGX_Spark_P4242")
        # Kernel
        KERNEL_VERSION="6.17.0-1014-nvidia"
        # DOCA/OFED
        DOCA_VERSION="3.2.1"
        DOCA_BUILD="044000-25.10"
        UBUNTU_VERSION="ubuntu2404"
        ARCH="arm64"
        # Docker
        DOCKER_VERSION="29.1.5"
        # GPU Driver
        GPU_DRIVER_VERSION="590.48.01"
        GPU_DRIVER_ARCH="aarch64"
        CUDA_VERSION="13.1.1"
        CUDA_RUN_FILE_NAME="cuda_${CUDA_VERSION}_${GPU_DRIVER_VERSION}_linux_sbsa.run"
        # GDRCopy (GPU Direct RDMA)
        GDRDRV_VERSION="2.5.1-1"
        GDRDRV_CUDA_VERSION="13.0"
        GDRCOPY_UBUNTU_VER="ubuntu24_04"
        HUGEPAGES="24"
        LINUXPTP_VERSION="4.2"           # available via apt on Ubuntu 24.04
        NIC_DEV="/dev/mst/mt4129_pciconf0"
        ISOLCPUS="4-19"
        # PTP services: pin to CPU 4 (override with PTP_CPU_AFFINITY=<cpu number> if needed). Empty = unpinned.
        PTP_CPU_AFFINITY="${PTP_CPU_AFFINITY:-4}"
        # build_aerial_sdk.sh args
        AERIAL_BUILD_FLAGS="${AERIAL_BUILD_FLAGS:- --cuda-archs 121}"
    "Supermicro_ARS-111GL-NHR")
        # Kernel
        KERNEL_VERSION="6.8.0-1025-nvidia-64k"
        # DOCA/OFED
        UBUNTU_VERSION="ubuntu2204"          # Ubuntu 22.04
        ARCH="arm64"
        # Docker
        # GPU Driver
        GDRCOPY_UBUNTU_VER="ubuntu22_04"
        HUGEPAGES="48"                       # 48 × 512M = 24GB (GH200)
        LINUXPTP_VERSION="4.2"           # must build from source on Ubuntu 22.04
        BFB_VERSION="3.2.1-34_25.11-prod"   # BlueField3 BFB bundle version
        NIC_DEV="/dev/mst/mt41692_pciconf0"
        ISOLCPUS="4-64"
        # PTP services: unpinned for SMC (empty). Set PTP_CPU_AFFINITY= to pin if desired.
        PTP_CPU_AFFINITY="${PTP_CPU_AFFINITY:-}"
        AERIAL_BUILD_FLAGS="${AERIAL_BUILD_FLAGS:- --cuda-archs 90}"
    "ASUS_Pro_WS_W790_ACE")
        # Kernel
        KERNEL_VERSION="$(uname -r)"
        # DOCA/OFED
        ARCH="amd64"
        # Docker
        # GPU Driver
        GPU_DRIVER_ARCH="x86_64"
        CUDA_RUN_FILE_NAME="cuda_${CUDA_VERSION}_${GPU_DRIVER_VERSION}_linux.run"
        # GDRCopy
        HUGEPAGES="48"
        # Intel W790
        ISOLCPUS="4-19"
        # PTP
        # RTX 4090 / L40S / Ada: 89
        # H100 / H200 / GH200: 90
        # RTX PRO 6000 Blackwell / B200 类: 120 或 121,
        AERIAL_BUILD_FLAGS="${AERIAL_BUILD_FLAGS:- --cuda-archs 120}"
    # Add other platforms as needed
    # example_platform)
    #     KERNEL_VERSION="x.x.x"
        echo "[ERROR] Unknown platform DMI ID: $PLATFORM"
        echo "[ERROR] Supported platforms and their DMI board_vendor_family_name_board_name:"
        echo "        NVIDIA_DGX_Spark_P4242:"
        echo "           NVIDIA_DGX_Spark_NVIDIA_DGX_Spark_P4242"
        echo "        Supermicro_ARS-111GL-NHR:"
        echo "           Supermicro_Family_Super_Server_G1SMH-G"
        echo "           Supermicro_Family_ARS-111GL-NHR_G1SMH-G"
        exit 1
esac
cuPHY-CP/cuphycontroller/config/cuphycontroller_P5G_WNC_GH.yaml
nic: '0000:85:00.0'
Great work. Thanks for sharing with the community.
