Hello, nvidia
Our custom carrier board is being upgraded from JP5.1.1 to JP5.1.2 to support industrial orin, but after the upgrade, I found that I could not enter the system normally. The following is all the logs output by the serial port, can you help me parse its errors?
BTW,
My device is 32G AGX orin moules.
error_log.txt (133.4 KB)
please check
Hi, WayneWWW
You are right, after using this configuration,
I successfully entered the system, but my HDMI interface did not display properly.
it seems that I need to use dtb_tool to regenerate the device tree file? Can I use./flash -k A_kernel-dtb to refresh a new dtb file?
