Frontend bug: Illegal context for the component reference
This is most likely a follow-up on
module debug_m
  implicit none
  private
  public :: debug_t, debug
  type debug_t
    logical :: trace
  end type debug_t
  type(debug_t), save :: debug
end module debug_m
module base_m
  implicit none
  private
  public :: base_t
  type, abstract :: base_t
  contains
    procedure(base_debug), deferred :: debug
  end type base_t
  abstract interface
    subroutine base_debug(this)
      import :: base_t
      class(base_t), intent(in) :: this
    end subroutine base_debug
  end interface
end module base_m
module derived_m
  use debug_m
  use base_m
  implicit none
  private
  public :: derived_t
  type, extends(base_t) :: derived_t
  contains
    procedure :: debug => derived_debug
  end type derived_t
contains
  subroutine derived_debug(this)
    class(derived_t), intent(in) :: this
  end subroutine derived_debug
  subroutine some_routine()
    if (debug%trace) then
      continue
    end if
  end subroutine some_routine
end module derived_m
The code above is a bit more verbose to keep it structured and readable. It is rejected by nvfortran with some weird error messages.
$ nvfortran --version
nvfortran 26.5-0 64-bit target on x86-64 Linux -tp icelake-server
NVIDIA Compilers and Tools
Copyright (c) 2026, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
$ nvfortran -c test.f90
NVFORTRAN-S-0155-Illegal context for the component reference to trace (test.f90: 50)
NVFORTRAN-F-0141-Derived Type object required on left of % (test.f90: 50)
NVFORTRAN/x86-64 Linux 26.5-0: compilation aborted
However, that code is accepted by other compilers, including NAG (known for its strict standard compliance) which only complains about unused variables and missing labels
$ nagfor -c test.f90
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7200
Warning: test.f90, line 47: Unused dummy variable THIS
Note: test.f90, line 51: CONTINUE statement with no label
[NAG Fortran Compiler normal termination, 2 warnings]
Hi Henri,
Thanks for the report. Looks like we found this one already and have a fix in place in our development compiler. Presuming testing goes well, the fix is scheduled to be included in our next release in September. I’ve added your issue to the same report, TPR #38722, to remind myself to update this post once the next release is available.
-Mat
Hi - just writing to let you know that this issue should be resolved with the release of 26.9 today. Please let us know if you run into anymore issues!
Cheers,
Seth.
