Frontend Node's minimum system requirements of Aerial omniverse digital twin
Hi team,
In the aerial omniverse digital twin installation guide, lists some example GPU of fronted node like RTX 6000 Ada, A10, L40.
And in the original omniverse digital twin installation guide, lists minimum spec, good and ideal system requirements.
What is the minimum system requirements for aerial omniverse digital fronted node?
@jing.tong We do not publish minimum specs. A lower spec than the recommended one will result in a diffrent user experience that we cannot predict.
Can I use the original omniverse digital twin publishment as a reference? Or Aerial omniverse digital twin frontend node needs higher requirements on GPUs?
@kpasad1 could you answer the question of Tong Jing, thanks.
And another question is if driver version is strictly required as document, or newer one can be used, Thanks.
@ermao.zhang2 @jing.tong We have not qualified AODT for GPUs and OS versions outside of what is specified in AODT documentation. This means that there is no guarantee that AODT will work, and provide a reasonable user experience. An OS version of 18.04 will be very challenging. We recommend at least 22.04. Same with the driver requirement- a lower version may result in unpredictable behaviour.
