Any recommended FTDI USB to UART dongle/adapter for Jetson Family(AGX Xavier ,NX) of modules/boards? I have seen many discussion on the forum but could not get any recommended tested device detail
Pretty much all FTDI serial UARTs will work without issue. The choice is usually based on which wires you want to be present. Some are only ground and TX and RX wires. Others also have RTS and CTS for flow control. You can always not use CTS/RTS if not needed, so I recommend having them. Some also use a standard layout 0.1" spacing header; if you use the header then you can use individual breakout wires on it.
Almost forgot, but very important: It should use 3.3V signal level.
