fTPM Implementation and Provisioning
Hello there,
I have two questions regarding Jetson fTPM installation.
First, we are using a preconfigured Jetson Linux version based on R36.4.3, along with a custom carrier board rather than the original one used for Orin NX. I was unable to find the optee directory within our image files. As suggested in the official guidelines, I retrieved the optee directory by downloading a fresh BSP package. I understand that compatibility depends on our specific configuration, but I would like to know if you believe this approach could cause any conflicts.
My second question is about the FSKP package. According to the documentation, it is a partner release package. Is there any way to test the fTPM provisioning process without burning fuses or making permanent hardware changes? I would like to avoid risking any damage to our devices during initial testing.
Thank you for your time.
Hi mehmetyusuf1414,
Please download them from Driver Package (BSP) Sources.
It should be also working on your custom carrier board. fTPM is SW implementation.
I think burning fuse is necessary in this use case.
May I know what’s your use case and requirement?
Hello Kevin,
Thank you for your reply.
We are developing security solutions using various camera systems and sensors, with a focus on ALPR systems. We require fTPM to secure our custom image installations on Orin NX modules.
I’m still exploring the full capabilities of fTPM, so I may be referring to some use cases incorrectly. However, I’m confident that we will need to utilize fTPM in our project.
Thank you again for your time.
For fTPM feature on Jetson, you can refer to Firmware TPM — NVIDIA Jetson Linux Developer Guide for details.
Kevin, thank you for referring me to the guideline.
I have been following it to learn more about fTPM, but I assume that testing fTPM is not possible without burning the fuses—is that correct?
Thank you once again.
Correct, burning the fuse is required to verify fTPM.
I have one more small question,
The Official TPM 2.0 Reference Implementation (link) can be used to simulate fTPM Provisioning, right? This allows us to test the process safely I assume.
We’ve not verified that locally, but it seems worth to try if you want to simulate TPM2.0.
