Fullscreen Direct3D 11 multi device (gpu), multi swap chain per device rendering
In my application I seem unable to achieve more than one device (GPU) in fullscreen at the same time. After much testing and googling I still remain puzzled. Windowed mode is not an option for me, and multi device is essential.
I can get multiple swap chains on a single device to go fullscreen at the same time, but as soon as more than one device is going fullscreen, a maximum of one device remains in fullscreen mode.
I also found this blog stating the problem:
Is it possible to achieve fullscreen rendering on multiple devices using DirectX 11 on Windows 8/7? If yes, how would that be achieved? If not, what’s the rationale behind it?
Looking for solutions for DirectX 11, I found a webpage stating that DirectX 9 could be used in fullscreen mode on multiple devices if some restrictions are met:
“… The practical implication is that a multiple monitor application can place several devices in full-screen mode, but only if all these devices are for different adapters, were created by the same Direct3D9 object, and all share the same focus window…”
Source: http://msdn.microsoft.com/en-us/library/windows/desktop/bb206364(v=vs.85).aspx
Are there similar restrictions as with DX9 for DX11 on Windows 8 and how could they be met?
If fullscreen rendering on multiple devices is not possible using DirectX 11 (for some reason I would like to know), could it be possible to interop between DX9 and DX11 to get it working?
I also read in a blog that Windows Vista might work with multiple fullscreen devices since it uses DXGI 1.0.
I would really appreciate some comments on this issue.
Best regards,
Jørn Skaarud Karlsen
