Is function call overhead significant in OpenCL-C or does the compiler just inline calls anyway since there is no real stack? Is it best to inline code by hand that otherwise would be written as a separate (non-kernel) function?
Thanks in advance.
Thanks in advance.
Thanks in advance.
I think all the function calls are inlined.
How should parameter passing be done in order to get best performance?
float4 someFunction(float4 arg1, float4 arg2);
__kernel ..... {
float4 a=..., b=...;
float4 c = someFunction(a,b);
or
float4 someFunction(float4* arg1, float4* arg2);
__kernel ..... {
float4 c = someFunction(&a,&b);
Does it matter? My theory was to avoid a copy of the parameters by passing as pointers, but not sure what will happen in the background with these pointers.
__kernel ..... {
or
__kernel ..... {
In theory, it’s better to use pointers but, in practise, use the profiler or regcount :P
