Does CUDA support call recursion for function? Something like:
struct Node
int i;
Node *child;
void IterateTree ( Node* node )
//do something
IterateTree(node->child);
or is stackless/inlines automatically all the function calls?
thx
Function calls are inlined.
Paulius
No, recursive calls don’t work - it is stackless.
You can use function template recursion if the recursion can be unrolled completely by the preprocessing step (see nvcc -v what happens), ie. if the terminating expression can be computed at compile time.
Peter
