function_traits with __device__-tagged lambdas
I’m trying to get the types of arguments for a lambda or functor. I tried using the function_traits proposal that is detailed here
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwim-vTH8ZPLAhXLGB4KHYrzC7cQFggpMAI&url=https%3A%2F%2Fgooglegroups.com%2Fa%2Fisocpp.org%2Fgroup%2Fstd-proposals%2Fattach%2Fcf44433fc0d73ccf%2FProposal_to_add_lambda_traits.pdf%3Fpart%3D0.1&usg=AFQjCNFCl84sULA-FGfPOJFrkg1sTZb6bg&sig2=OQJdzq_SSSIRDuRzn6RWjQ
It works by specializing function_traits over the type of the operator() class method pointer, from which a variadic args_t… can be extracted, and tuple_element can then give access to the types of any of that list. But this all breaks with a device-tagged lambda. Has anyone found a way around this?
#include <tuple>
#include <typeinfo>
template<typename func_t>
struct function_traits :
  public function_traits<decltype(&func_t::operator())> { };
template<typename class_type, typename return_type_, typename... args_t>
struct function_traits<return_type_(class_type::*)(args_t...) const> {
  typedef return_type_ return_type;
  enum { arity = sizeof...(args_t) };
  template<size_t i>
  struct arg {
    using type = typename std::tuple_element<i, std::tuple<args_t...> >::type;
using return_type = typename function_traits<func_t>::return_type;
using arg0_type = typename function_traits<func_t>::template arg<0>::type;
using arg1_type = typename function_traits<func_t>::template arg<1>::type;
using arg2_type = typename function_traits<func_t>::template arg<2>::type;
int main(int argc, char** argv) {
  auto k = [](int value, double index) {
    return (float)(value * index);
  typedef return_type<decltype(k)> value_type;
  typedef arg0_type<decltype(k)> arg0;
  typedef arg1_type<decltype(k)> arg1;
  printf("Types for return: %s  arg0: %s  arg1: %s\n",
    typeid(value_type).name(),
    typeid(arg0).name(),
    typeid(arg1).name());
