This is the code section that I am trying to accelerate.
!$acc region copyin (k,yxv,f,route) copyout(vtx) local(phase3,ctemp)
!$acc do parallel
DO p = 1,npoints
DO i = 1,nterms
phase3 = CMPLX(0,0.5d0) * SUM( k(:,1:order+1,p)*yxv(:,1:order+1,i) )
ctemp = f(i) * EXP(phase3)
vtx(0,0,0,p) = vtx(0,0,0,p) + ctemp
END DO
END DO
!$acc end region
I get the following message
main:
64, Accelerator region ignored
67, Accelerator restriction: function/procedure calls are not supported
68, sum reduction inlined
69, Accelerator restriction: function/procedure calls are not supported
It seems CMPLX, SUM and EXP functions are not supported? Is there any work around?
CMPLX is not supported. SUM and EXP are supported just not for Complex data types. For a complete list of supported intrinsics, please refer the Chapter 7 of PGI User’s Guide (http://www.pgroup.com/doc/pgiug.pdf).
You could replace “CMPLX(0,0.5d0)” with a variable initialized on the host. For sum, you would simply add another loop to perform the summation. Unfortunately, I can’t think of anything for EXP.
After further research, i.e. reading more of the PGI manuals, I see that CMPLX really is not supported, as shown in Table 7.5 of the User Guide. In fact, comparing Table 7.5 with the list of supported intrinsics shown in the Fortran Reference manual, there are quite a few intrinsics not supported. To the HPC community things like DOT_PRODUCT and TRANSPOSE, just to mention two that are not supported in any intrinsic data type, must crop up all of the time! This has got to be a real draw back to the adoption of the Accelerator product!!
Thanks for your replies. Appreciate your time and effort.
We currently got the latest version of pgfortran 10.6. Complex arithmetic seems to be not working on this still.
INTEGER, ALLOCATABLE :: yxv(:,:,:)
COMPLEX(kind=cx_kind), ALLOCATABLE :: k(:,:,:)
COMPLEX(kind=cx_kind), ALLOCATABLE :: vtx(:,:,:,:)
COMPLEX(kind=cx_kind) ctemp, phase3
!$acc region
!$acc do
DO p = 1,npoints
phase3 = 0
DO r = 1,order+1
DO mu = 0,NDIR-1
ctemp = k(mu,r,p)
DO i = 1,nterms
phase3 = phase3 + ctemp*yxv(mu,r,i)
END DO
END DO
END DO
vtx(0,0,0,p) = phase3
END DO
!$acc end region
I get the following message.
Accelerator restriction: struct/member references are not yet supported: imag(ctemp)
Accelerator restriction: struct/member references are not yet supported: real(ctemp)
I checked with our compiler engineers. Complex arithmetic is supported, however this is a bug where the unroller where isn’t copying the complex offset for complex scalar variables. They had found this a internally and have a fix in place for the 10.8 release.
