Hello
I have about 10 different boards with TK1 that I cannot burn fuses, with the error being always the same.
bootloader status: bad parameter to method or interface (code: 5) message: FuseWrite 5805 flags: 0
command failure/warning: bootloader error
This doesn’t happen with most of the boards we have, over 100 were fused correctly with the same executable and fastboot.bin
this is the command I use to fuse them
#!/bin/bash
eval './nvflash --writefuse odmfuse_pkc.cfg --bl fastboot.bin --go'
for reference the full logs from fusing
Successful fuse:
Nvflash 4.13.0000 started
BR_CID: 0x340010017410c1060800000012020580
rcm version 0X400001
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017410c1060800000012020580
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
\ 1253616/1253616 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
- 384/384 bytes sent
Fuse details downloaded successfully
Time taken for flashing 2 Secs
Failed fuse:
BR_CID: 0x340010017410b0c90000000016fb8240
System Information:
chip name: unknown
chip sku: 0x0
chip uid: 0x000000017410b0c90000000016fb8240
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
Thank you for your time
