Fuseblob to enable FTPM
I am trying to evaluate FTPM on AGX Orin using the 36.4 SDK.
I took the reference config at Firmware TPM — NVIDIA Jetson Linux Developer Guide 1 documentation and make the following changes
With few exceptions (eg ECDSA-P256 PKC), keep keys as all zeros to avoid blowing fuses
Remove OptInEnable option. Setting OptInEnable to 0x1 enables anti-rollback and we do not need this now.
  • Remove ArmJtagDisable option. Setting ArmJtagDisable to 0x1 permanently prevents any JTAG access to the debug access port
  • Remove SecurityMode option. Setting SecurityMode to 0x1 locks the values of the other manufacturing fuses.
  • Remove PkcPubKeyHash1 and PkcPubKeyHash2. These are spare keys in the case of PKC revocation, do not need this now for testing.
  • Set BootSecurityInfo to 0x020A
[BIT]  15 14 13 12 11 10 09 08 07 06 05 04 03 02 01 00
[VAL]   0  0  0  0  0  0  0  0  0  0  0  0  1  0  1  0
Bits [2:0] mapped to Secure Boot Authentication Scheme, where 010b: ECDSA P-256 Curve
Bit [3] secure boot encryption scheme (SBK), where 1b: enable
Bit [9] ODM Key Valid, where 0b: This bit should be enabled only when OEM_K1 and OEM_K2 are burned.
        Set this to 0 since we have OEM_K1 and OEM_K2 equal to all zeros
Since programming the fuses is a one-time operation, I want to err on the side of caution. My goal is to do just enough to enable FTPM, while still remain as flexible as possible.
Can I get some eyes on to review the attached fuse configuration file before I go ahead?
<genericfuse MagicId="0x45535546" version="1.0.0">
   <fuse name="OdmInfo" size="4" value="0x0000"/>
   <fuse name="OdmId" size="8" value="0x0000000000000000"/>
   <fuse name="Kdk0" size="32" value="0x0000000000000000000000000000000000000000000000000000000000000000"/>
   <fuse name="PublicKeyhash" size="64" value="redacted-ecdsa-p256-pubkey-hash"/>
   <fuse name="SecureBootKey" size="32" value="0x0000000000000000000000000000000000000000000000000000000000000000"/>
   <fuse name="OemK1" size="32" value="0x0000000000000000000000000000000000000000000000000000000000000000"/>
   <fuse name="OemK2" size="32" value="0x0000000000000000000000000000000000000000000000000000000000000000"/>
   <fuse name="PscOdmStatic" size="4" value="0x00000060"/>
   <fuse name="BootSecurityInfo" size="4" value="0x000A"/>
</genericfuse>
Hi tanlu,
Could you elaborate on this about “remain as flexible”?
hello tanlu,
it’s crucial to double check your BootSecurityInfo.
please refer to Jetson Orin Fuse Specification to review FUSE_BOOT_SECURITY_INFO_0.
for instance, although you’ve BootSecurityInfo=0x000A, but you’ve all 0s SBK keys…
anyways,
as mentioned by developer guide, Burn Fuses with the Fuse Configuration file.
it’s recommends burning all the fuses you need in a single operation.
