Hi ,
We are trying out mass flash , to create mass flash blob with offline method we used below command
sudo BOARDID=<boardid> BOARDSKU=<sku> FAB=<fab>
BOARDREV=<rev> FUSELEVEL=fuselevel_production ./nvmassflashgen.sh
<device name> mmcblk0p1
Let us know what is the significance of FUSELEVEL parameter ? @WayneWWW
hello _darshan_m,
FUSELEVEL
parameter to specify this is fused or non-fuse device.
Hi ,
Thanks for replay.
We would like to know the significance of FUSELEVEL parameter, is there any document to get more info on fused and non fused device?
Darshan
hello _darshan_m,
please check Secure Boot chapter.
you’ll need to burn the keys, PKC or PKC+SBK to enable Jetson security, then you have a fused device.
beware, fuse programming is non-reversible, once a fuse bit is programmed by setting to 1, you cannot change the fuse value from 1 to 0.
Hi ,
Thanks for sharing .
In our case we are using below command to create mass-flash blob.
so , “FUSELEVEL=fuselevel_production” parameter will not actually burn any fuse on setup right ?
Darshan
hello _darshan_m,
FUSELEVEL
it’s the parameter to assign the fuse info. it won’t perform fuse burn to the target.
Hi ,
Thanks for information
Darshan
system
Closed
September 7, 2022, 2:47am
10
