Fuzzy C Means CUDA
hay i am working my thesis about using FCM ini CUDA
and i got an example and permissions from Mr Soroosh Bateni codes from gitHub
i try to compile main program lfcm.cu in visual studio 2010 and it aint work
any one can help?
the source here https://github.com/Soroosh129/GPU-FCM
any one can help?
“hay”
you need an entry point to debug; “it aint work” is hardly an entry point
hypothetically, either the good Mr Soroosh Batenti provided you with erroneous code, or you are violating the premises of the code:
perhaps check that you have a corresponding platform, and perhaps also a corresponding device, particularly if the code is ‘device-sensitive’
i wanted to show through logical argument that “working my thesis” generally implies a natural aptitude to troubleshoot, but decided against it
yes i can help you can start your code and give me access using team viewer sarabjeet_singh13@yahoo.com
