Hello
My setup: Jetson TX2 + U-boot with enabled CONFIG_BOOTCOUNT_LIMIT
and CONFIG_BOOTCOUNT_ENV
Configuration of /etc/fw_env.config
looks like:
/dev/mmcblk0boot1 0x3fe000 0x2000
Problem is: fw_printenv
and U-boot internal shell shows me different values.
Example: I set “bootlimit” variable to 10 via “fw_setenv” then reboot device, open U-Boot shell and “printenv bootlimit” shows me 2 instead of 10.
Or vice versa: when I tried to write variable from U-Boot via “setenv bootlimit 20” then run “saveenv”, reboot to Linux and “fw_printenv” shows me “10”
I tried to change /dev/mmcblk0boot1 to /dev/mmcblk0boot0 in /etc/fw_env.config but no luck
