FW upgrade fail
There’s new firmware available for the FE Spark, but upgrade fails with:
║ Upgrade Embedded Controller from 0x03000508 to 0x03000d07?                   ║
║ This update improves the performance and stability of the Embedded           ║
║ Controller in DGX Spark                                                      ║
║ NVIDIA_DGX_Spark must remain plugged into a power source for the duration    ║
║ of the update to avoid damage.                                               ║
Perform operation? [Y|n]:
Downloading…             [                     \                 ]
Transient failure to download, server response was 504: error code: 504
Update:
There are 502 and 504 errors now:
  1. 502 Bad Gateway
  2. 504 Gateway Timeout
Looks like LFVS servers are busy!
I also got something similair today. Running sudo fwupdmgr refresh --reload consistently gave a 504 timeout message, but it doesn’t timeout for me anymore now.
And I am noticing the Updates tab from the dashboard is taking ages to load. Could be related?
Hello! We are actively monitoring this update-related concern and are working with our partners to resolve the matter. I’ll circle back to this case with further updates as they become available.
We apologize for any inconvenience; we hope to get this resolved quickly.
Getting same issue. Hang on updates dashboard
Edit: i rebooted and only saw the 3 firmware updates. seems to be going through now - will keep u updated
firmware updates finally applied and there was several reboots - thanks!
It appears that some CDNs are either down, unresponsive or broken right now. A possible workaround is:
sudo fwupdmgr modify-remote lvfs MetadataURI https://fwupd.org/downloads/firmware.xml.zst
Then once the problem is solved, revert the change:
sudo fwupdmgr modify-remote lvfs MetadataURI https://cdn.fwupd.org/downloads/firmware.xml.zst
That worked fine for me today.
This workaround helped unblock my cluster, tyvm for sharing!
Is it safe to interrupt a partial update process?
I need to restart my Sparks and want to try the workaround posted by vedrin.jeliazkov, but I don’t know if triggering a restart with incomplete updates might cause problems.
The issue is ongoing this morning. The updates on all four of my Sparks have not progressed over the past two hours or so. Two Sparks show zero progress, the other two are stuck somewhere in the middle of the green bar of the dashboard.
I had all 4 of my FE Sparks get stuck for an hour after using the DGX Dashboard to roll out the updates.
One reboot and fw update using CLI later on each node and everything is working again.
We can confirm that the slowdowns and timeouts related to SW and FW updates was resolved last night. If you are still having trouble upgrading your Spark to the latest versions, please let me know.
My 4 units got stuck at 14:30 UK time today, in case there are any more gremlins lurking in the CDN.
i tryed to Update over the “DGX Spark Dashboard” and it restart and everything but the Update is still displayed as "Available Updates System Update"
[ASUS Ascent GX10]
@mashie: Awesome, thanks for the confidence boost. I took the plunge and rebooted - no issues so far.
Perhaps the issue was merely related to stalled progress bars in the dashboard, because neither the dashboard nor fwupdmgr get-updates show any available updates since manually rebooting the Sparks - so the actual updates seem to have succeeded.
@aniculescu: Thanks for confirming the resolution of the earlier issue. But there definitely remains an issue with the update process, because the Sparks usually reboot themselves after completing their updates. None of my four Sparks rebooted themselves this time.
I updated today, neither GB10 rebooted, didnt see any firmware update, but dashboard did say there was a firmware update. I refreshed the dashboard page and then it showed no updates available, no update in progress.
Rebooted both nodes for good measure, both rebooted normally.
Dont see any updates available in dashboard.
[MSI EgdeXpert]
That matches my experience on my four Lenovo PGX ThinkStations.
The dashboard definitely said there was new firmware available before I started the update, but I checked fwupdmgr get-history to confirm that no new firmware was installed today. Nevertheless, the dashboard now says No Available Updates.
I’m not sure why the Dashboard would not reboot after a firmware upgrade, but you can check if a reboot is still needed by running fwupdmgr check-reboot-needed in a terminal.
If you have an OEM device, there may be a delay before you have access to the newer firmware.
Huh, that check appears broken. All four machines respond with:
An update requires the system to shutdown to complete. Shutdown now? [y|N]:
So I let one of my Sparks shutdown and restart, retried the command but received the same response. I shutdown again and retried the command. Same response. I shutdown a third time and restart - still, I receive the same response.
After three shutdowns, the command fwupdmgr check-reboot-needed still wants to shut down my Sparks…
So I tried the command on my Laptop and on my other server… ha, same response!
That command is false advertisement :)
That makes sense, but does not really explain why the dashboard said a firmware update would be available earlier today but no no longer shows an available update - despite no recent firmware installations.
We’ve recently found an issue with the dgx-dashboard package. Currently working on a fix
glad I did not click there yet.
have the same behavior like kevinpw mentioned (ASUS Ascent GX10)
Two back to back problem updates. You would think there are some internal testing before being deployed to the public..
