Fwupd daemon failure
After initially setting up my Lenovo PGX, the upgrade through the DGX Dashboard failed. After trying the manual update (that did not update anything) I noticed the following error:
Jun 10 00:26:30 thinkstationpgx-1b01 fwupd[190536]: Failed to load daemon: failed to load engine: libfwupd version 1.9.34 does not match daemon 1.9.30
After some googling around I fixed it by upgrading fwupd with the following command:
sudo apt upgrade fwupd
and it upgraded to version 2.0.20:
fwupd.service - Firmware update daemon
Loaded: loaded (/usr/lib/systemd/system/fwupd.service; static)
Active: active (running) since Wed 2026-06-10 01:19:58 CEST; 14min ago
Docs: https://fwupd.org/
Main PID: 229411 (fwupd)
Tasks: 4 (limit: 153551)
Memory: 20.7M (peak: 29.4M)
CPU: 411ms
CGroup: /system.slice/fwupd.service
└─229411 /usr/libexec/fwupd/fwupd
Jun 10 01:19:57 thinkstationpgx-1b01 systemd[1]: Starting fwupd.service - Firmware update daemon…
Jun 10 01:19:57 thinkstationpgx-1b01 fwupd[229411]: 23:19:57.937 FuPluginUefiCapsule failed to get screen size: failed to setup: failed to get DRM resources
Jun 10 01:19:58 thinkstationpgx-1b01 fwupd[229411]: 23:19:58.184 FuMain fwupd 2.0.20 ready for requests (locale en_US.utf8)
Jun 10 01:19:58 thinkstationpgx-1b01 systemd[1]: Started fwupd.service - Firmware update daemon.
Was this the right way to fix this problem and can I run firmware updates safely now? Why was the sudo apt dist-upgrade command not upgrading fwupd?
kind regards
E
For anyone interested, I had no problems running the firmware upgrade after specifically upgrading fwupd.
