There’s a new kernel available but the Nvidia driver is missing.
In my case some of the packages were held back, the one with the driver also, and after running sudo apt full-upgrade the missing driver issue was fixed!
Not sure what process you may have followed that led to this, but I’ve updated both of my Sparks about two days ago without issues, following the recommended steps in the OS and Component Update Guide — DGX Spark User Guide :
I’m running the ‘new’ kernel and all the drivers are present:
zgx-spark:~$ uname -a
Linux zgx-spark 6.17.0-1021-nvidia #21-Ubuntu SMP PREEMPT_DYNAMIC Wed May 27 19:14:05 UTC 2026 aarch64 aarch64 aarch64 GNU/Linux
zgx-spark:~$ modinfo nvidia | head
filename: /lib/modules/6.17.0-1021-nvidia/kernel/nvidia-580-open/nvidia.ko
import_ns: DMA_BUF
alias: char-major-195-*
description: NVIDIA core GPU kernel module
version: 580.159.03
supported: external
license: Dual MIT/GPL
firmware: nvidia/580.159.03/gsp_tu10x.bin
firmware: nvidia/580.159.03/gsp_ga10x.bin
softdep: pre: ecdh_generic,ecdsa_generic
I think if you stick to the recommended upgrade process, you won’t run into these issues.
However, if you opt to update the drivers beyond the platform-supported versions listed in the Release Notes — NVIDIA DGX OS 7 User Guide , then yah, you’ll run into some oddball issues.
I hit this issue as well, in the end I did a full system restore. FYI installing nvidia-580-open resulted in a self-signed module on my MSI EdgeXpert, I needed to enroll my own keys for secure boot. It would be better to install a package which comes with the module prebuilt and signed by Nvidia.
I’ve got the same issue after updating to 6.17.0-1021-nvidia kernel. Nvidia driver doesn’t get loaded with it.
For now I fixed it by going back to 6.17.0-1018-nvidia kernel. As I still had it installed (checked with aptitude search ~ilinux- first), I simply removed 6.17.0-1021-nvidia by running
Today I ran into the same issue. I always run: sudo apt update sudo apt upgrade --dry-run sudo apt update && sudo apt upgrade -y sudo reboot nvidia-smi uname -r
After the reboot, nvidia-smi spat out an error saying that the driver was missing… Luckily, I had a hunch to check the DGX Dashboard. Even though sudo apt upgrade --dry-run wasn’t returning anything anymore, the DGX Dashboard showed that an update was available. I figured it wouldn’t hurt to click it and see what happens – after the reboot, everything worked perfectly.
Just so I understand properly, I should NOT hit any issues if I update from the dashboard, correct?
I always update over the command line as I have a headless setup, so probably nVidia should change their approach here for the spark :) I held off from updating because of this thread, but if everyone agrees that Dashboard’s update goes smoothly, I’ll do that.
