I spent a few hours collecting this information from a few places today, and thought I’d share it with the forum. This is for setting up a console-mode only server with multiple cards, using the new 2.2 exclusive access feature.
TO INSTALL CUDA ON AN UBUNTU CLUSTER SERVER:
Follow NVIDIA’s Ubuntu Linux instructions to install the driver and toolkit (and optionally the SDK). Expect difficulties with making sure the driver is running and that the necessary /dev/nv* devices are being created at system startup. Instructions below will sort that out.
(1) Set Ubuntu to boot to console mode only.
> sudo vi /etc/X11/default-display-manager
* Comment out the line containing "gdm".
* Create a new line consisting of the word "false" (no quotes).
(2) Create a script that will create the necessary /dev/nv* devices on startup.
> cd /etc/init.d
> sudo vi nvidia_create_devices
* Paste in the script below.
* Edit the script to make sure the number of "nvidia-smi -g" commands matches the number of devices.
* Save the script.
> sudo chmod a+x nvidia_create_devices
(3) Make sure the script gets run at startup.
> sudo update-rc.d nvidia_create_devices defaults
== Script: nvidia_create_devices ==
#!/bin/bash
PATH=$PATH:/usr/local/cuda/bin
modprobe nvidia
if [ “$?” -eq 0 ]; then
Count the number of NVIDIA controllers found.
N3D=/usr/bin/lspci | grep -i NVIDIA | grep "3D controller" | wc -l
NVGA=/usr/bin/lspci | grep -i NVIDIA | grep "VGA compatible controller" | wc -l
N=expr $N3D + $NVGA - 1
for i in seq 0 $N
; do
mknod -m 666 /dev/nvidia$i c 195 $i;
done
mknod -m 666 /dev/nvidiactl c 195 255
nvidia-smi --loop-continuously --interval=60 --filename=/var/log/nvidia-smi.log &
nvidia-smi -g 0 -c 1
nvidia-smi -g 1 -c 1
nvidia-smi -g 2 -c 1
nvidia-smi -g 3 -c 1
else
exit 1
fi
