FYI: new firmware available!
The update for the GX10 is available via the local dashboard or via the CLI. Mine was updated just fine.
The one on the support site from Asus is still from the 24th of March.
Everything went fine on the Asus GX10
sudo fwupdmgr upgrade
Devices with no available firmware updates:
 β€’ ESL01TBTLCZ-27J2-TYN
 β€’ UEFI dbx
β•‘ Upgrade Embedded Controller from 0x02000004 to 0x02000005?                   β•‘
β•‘ This update improves the performance and stability of the Device.            β•‘
β•‘        β•‘
β•‘ β€’ OTA2.2 EC hotfix release.                                                  β•‘
β•‘        β•‘
β•‘ GX10 must remain plugged into a power source for the duration of the update  β•‘
β•‘ to avoid damage.                                                             β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
Perform operation? [Y|n]: y
Waiting…                 [***************************************]
Successfully installed firmware
Do not turn off your computer or remove the AC adapter while the update is in progress.
β•‘ Upgrade UEFI Device Firmware from 0x03000005 to 0x03000006?                  β•‘
β•‘        β•‘
β•‘ β€’ Apply UEFI hotfix for GA2.0 OTA2.1.                                        β•‘
β•‘        β•‘
Updating UEFI Device Firmware…                                   ]
Devices with the latest available firmware version:
 β€’ UEFI Device Firmware
An update requires a reboot to complete. Restart now? [y|N]:
Also updated successfully two GX10 units. They rebooted several times so it took a while for them to come back online so I was a little worried but worked in the end.
It did not fix the sudden freezing at full gpu speed however, crashed pretty quickly for me so I’m back to capping one at 2150mzh.
thanks for the tip, as I use headless only via SSH i usually dont use that
Yeah does not fix the crappy ConnectX-7 issues FACEPALM
@aniculescu may be able to provide guidance. You might be told to run https://nvidia.custhelp.com/app/answers/detail/a_id/5767/~/nvidia-dgx-spark-field-diagnostics and to provide the Nvidia staff member with the logs. I was told to do this. You probably want to wait for someone from Nvidia to provide recommendations for the next steps. I’m not associated with Nvidia.
