The current pipeline, works with only one rtsp input stream:
rtsp 0-> uridecodebin ->nvstreammux → queue → nvmultistreamtiler → queue → nvvideoconvert → queue → nvosd → queue → nvvideoconvert → queue → capsfilter ->queue → nvv4l2h264enc → queue → rtph264pay → queue → udpsink → Rtsp Server
I want to extend the pipeline to work with multiple streams
rtspp 1 →
The problem is that when I call the following callback function:
g_signal_connect (G_OBJECT (bin), “pad-added”,G_CALLBACK (cb_newpad), &source_id);
where source_id is a gint with a value of 1
It seems as if data is not passed correctly into the cb_newpad function (below).
static void cb_newpad (GstElement * decodebin, GstPad * pad, gpointer data)
When the variable:
**gint source_id = *(gint *) data; **
is printed out in this callback function, it returns the value 0, and not 1.
This causes the second stream to fail because of the following error:
Element stream-muxer already has a pad named sink_00, the behaviour of gst_element_get_request_pad() for existing pads is undefined!
This is because the pad sink_00 has already been made for the first stream.
