I have not been able to prescribe gain values outside the range of [1-16] in nvarguscamerasrc even though the camera supports a much wider range. Whenever I try to set values beyond the [1-16] range, in the example below to [0-30], I get the following prompt and gain settings are ignored:
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 50000 1000000
GST_ARGUS: NvArgusCameraSrc: Setting Gain Range : 0 30
GST_ARGUS: Invalid Gain Range Input
The camera supports a gain range in the [0-72] range:
GST_ARGUS: 3840 x 2160 FR = 36.004002 fps Duration = 27774690 ; Analog Gain range min 0.000000, max 72.000000; Exposure Range min 50000, max 27685000;
Is [1-16] limit hardcoded into nvarguscamerasrc? If so, would it be possible to fix that?
