Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
5.1.0
Operating System
Ubuntu 22.04
GPU Information
- Model: geforce 3060
- Driver Version: NVIDIA-SMI 580.95.05, Driver Version: 580.95.05, CUDA Version: 13.0
Topic Description
Isaac Sim Gain Tuner extension triggers persistent errors even when the extension is disabled and no gain-tuning actions are performed.
Detailed Description
I am encountering a persistent Python error originating from the isaacsim.robot_setup.gain_tuner extension.
The issue occurs even though I am not using the Gain Tuner, and even after disabling the Gain Tuner extension in the Extensions window.
usdfile: https://github.com/TrossenRobotics/trossen_ai_isaac
What I was trying to do
I simply launched Isaac Sim, loaded my robot USD (mobile_ai), and pressed Play to run the simulation. I did not open the Gain Tuner window nor attempt any gain-tuning operation.
What I expected to happen
Simulation should run normally without any involvement of the Gain Tuner extension.
What actually happened
As soon as simulation starts, Isaac Sim repeatedly prints the following error from gains_tuner.py:
TypeError: 'NoneType' object is not an iterator
next(self._gains_test_generator)
This error loops continuously every frame, even after I disable the Gain Tuner extension (isaacsim.robot_setup.gain_tuner) and restart the simulation session.
It appears that the Gain Tuner callback (update_gains_test) continues to execute even when the extension is disabled.
Steps to Reproduce
Open Isaac Sim (5.1 version)
Load a robot USD (e.g.,
/mobile_ai/mobile_ai.usd) -
Press Play in the viewport
Observe console/log output
Disable the Gain Tuner extension:
Window → Extensions → gain tuner → disable
Restart simulation session and press Play again
The same error continues to appear every frame
Error Messages
File “…/isaacsim.robot_setup.gain_tuner/gains_tuner.py”, line 630, in update_gains_test
TypeError: ‘NoneType’ object is not an iterator
This message repeats continuously every frame.
Screenshots or Videos
Additional Information
Robot root articulation prim:
/mobile_ai/base_footprint -
ROS2PublishJointState and ArticulationController nodes are working normally
The error appears without opening the Gain Tuner interface
The error persists even after disabling the extension in the Extensions manager
The issue looks like the Gain Tuner callback remains registered and continues executing after extension unload
What I’ve Tried
Disabled the Gain Tuner extension from
Window → Extensions -
Restarted Isaac Sim after disabling the extension
Closed any Gain Tuner-related UI panels
Verified that other extensions are not dependent on Gain Tuner
Restarted simulation multiple times
None of these steps stop the update_gains_test() callback from executing.
Related Issues
Additional Context
This prevents normal simulation because the console is flooded with errors.
I am not intending to use the Gain Tuner at all, so I simply need a way to stop the callback from executing when the extension is disabled.
This may be a bug in the extension lifecycle or event callbacks not unregistering properly.
Add my usd file
mobile_ai_v1.zip (773.1 KB)
