GPU • DeepStream Version
6.0.1 • TensorRT Version
8.0.1.6 • NVIDIA GPU Driver Version (valid for GPU only)
470.86 • Issue Type( questions, new requirements, bugs)
Question • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
My problem is tightly related with Gating Metadata Flow. The only thing that is different is that I am using a probe instead of a custom plugin.
Let’s say you have a tee that’s split the pipe towards their own respective sinks; however, let’s further assume that we want one branch to continue on as normal to its sink, and the other one (just after being split) to gate in a stateful way the flow of metadata to its own sink, in order to modify the coordinates of its metadata objects.
I have tried the following without success:
static GstPadProbeReturn
msgconv_sink_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *)info->data;
// Create a copy of the metadata. This line does not make any difference. The metadata
// is still modified for the two branches of the pipeline.
if (!gst_buffer_copy_into (buf, buf, GST_BUFFER_COPY_META , 0, -1))
g_print ("Error: Buffer metadata copy failed \n");
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
NvDsObjectMeta *obj_meta = (NvDsObjectMeta *)l_obj->data;
obj_meta->rect_params.left -= 100;
obj_meta->rect_params.top -= 100;
return GST_PAD_PROBE_OK;
As soon as I modify the metadata in one of the branches it gets modified also in the other. Could you please help me?
Hi @eduardo.cuesta , tee plugin is not really copy the data to every branch. It just adds the gstbuf’s refcount. So if you don’t deep copy the gstbuf, all the brach actually use the same data. If you want to realize your functions, you can try to use the gst_buffer_copy_into function to deep copy your gstbuffer.
Hi @yuweiw , I have tried the deep copy (GST_BUFFER_COPY_DEEP) and the metadata is still modified at the other pipe branch:
gpointer u_data)
if (!gst_buffer_copy_into (buf, buf, GST_BUFFER_COPY_DEEP , 0, -1))
Oh I think I am not copying the data as the function gst_buffer_copy_into does nothing if both input buffers are the same: gst_buffer_copy_into (buf, buf, GST_BUFFER_COPY_DEEP , 0, -1).
Finally, I have realized that this is not fully working… I am losing some metadata for the secondary classifiers. It is weird, because I have the metadata of the primary detectors but I do not have all the metadata for the secondary classifiers in latter plugins of the pipeline when I copy the buffer using the provided code. Concretely, I am lossing the classifier_type property from the classifier_meta elements of the classifier_meta_list of each object.
Basically, you only need to copy the buffer once after the tee plugin.
Could you provide your code if it’s simple to run and your pipeline diagram? Thanks
Yes. You can commit your diff with our demo code. It’s better to have a particular README file. But if there are too many changes, it may take a long time to analyze your code.
