Hello,have any one one a code exapmle of gaussian blur on cuda. Thank you and have a nice day.
check the cuda sample codes:
[url]CUDA Samples :: CUDA Toolkit Documentation
go to the above page
search on “gauss”
search on “blur”
Hello Robert,
the link is really interesting but unfortunately, i can find code example. Is it normal ?
Alain
The link only shows a description of the sample code.
Unfortunately it seems the white paper link is broken.
The cuda sample codes (and this whitepaper) are installed on your machine if you installed a recent CUDA toolkit. Here they are on mine:
$ ls /usr/local/cuda/samples/3_Imaging/convolutionSeparable/
convolutionSeparable convolutionSeparable_gold.cpp doc Makefile
convolutionSeparable_common.h convolutionSeparable_gold.o main.cpp NsightEclipse.xml
convolutionSeparable.cu convolutionSeparable.o main.o readme.txt
$ ls /usr/local/cuda/samples/3_Imaging/convolutionSeparable/doc
convolutionSeparable.pdf
Many thanks Robert.
I suppose the examples are in /usr/local/cuda/samples (Jetson Nano).
I will take a look.
Alain
