• Hardware (NVIDIA GeForce 3090)
• Network Type (GazeNet)
Hey👋 Im having this realy wierd error when trying to load GazeNet .engine model in Triton.
Here are the steps:
I loaded model from:
Gaze Estimation | NVIDIA NGC -
Then converted it with:
tao-converter -k nvidia_tlt -p input_right_images:0,1x1x224x224,4x1x224x224,8x1x224x224 -p input_left_images:0,1x1x224x224,4x1x224x224,8x1x224x224 -p input_face_images:0,1x1x224x224,4x1x224x224,8x1x224x224 -p input_facegrid:0,1x1x625x1,4x1x625x1,8x1x625x1 model.etlt
When im trying to load it with triton i get realy wierd error
E0801 10:58:35.713590 753 model_repository_manager.cc:1348] failed to load 'gazenet' version 1: Internal: unable to allocate memory for output 'fc_joint/concat:0_before_shuffle' for gazenet
When its trying to run it, the peek of memry use is 950MiB then it crash
Befor run, the 3090 is fully unloaded from any process, to ensure there is no interference.
I tried to run it as automation config using model.plan and also added manual config file, still same error.
Yet what is intresting that trtexec --loadEngine=model.egine run model with no problem.
Here is some logs of Triton and trtexec:
Triton_full (25.1 KB)
trtexec.log (42.0 KB)
