GB10 abruptly powers off under heavy GPU load—<<nvidia-smi -lgc 300,2200>> prevents it
I want to document an issue I ran into on an HP ZGX Nano G1n (GB10, the same platform as the DGX Spark), along with what I found while debugging it.
The workload was a live camera feed going into vision-language models served with vLLM (through HP Z Runtime), using NVIDIA’s live-vlm-webui. Each inference took longer than the ~1 s frame interval, so requests ran back to back and the GPU was under load the whole time. vLLM was set to --gpu-memory-utilization 0.5, so only about half of the unified memory was reserved.
Under this load, the system would abruptly power off, several times. It was not a normal software crash or shutdown—the machine simply lost power.
System: kernel 7.0.0-1019-nvidia, NVIDIA open kernel module 580.178.04.
What the logs showed after the power-offs:
  • last -x listed two boots on the same day with no matching shutdown record, so neither ended with a clean shutdown.
  • journalctl -b -1 -e ended in the middle of routine activity, with no shutdown sequence and no kernel panic. On one occurrence the timeline was: inference job started at 06:47:47 UTC, GPU driver initialized at 06:47:54, journal stops at 06:48:52, next boot at 06:52. So the machine died within roughly 1–3 minutes of the GPU coming under load. The journal is flushed in batches, so the last line isn’t the exact moment of power loss.
  • journalctl -k -b -1 | grep -i -E "nvrm|xid|thermal|oom" on both affected boots returned only boot-time lines: no Xid, no NVRM errors, no NV_ERR_NO_MEMORY, no OOM kills, and no thermal messages. So it didn’t look like memory exhaustion or a GPU fault.
At the next boot, a few minutes after one of the power-offs, all seven ACPI thermal zones (TSOC, TS0E, TS0P, TS1E, TS1P, TGPU, TUNC) read 35–38 °C. The board reading that cool so soon after losing power, with the fans off, made me lean toward a power-related trip rather than overheating. But that’s a snapshot at boot, not a reading from the moment of failure.
As a workaround, I tried limiting the GPU clock:
sudo nvidia-smi -lgc 300,2200
After applying this limit, the shutdown issue stopped occurring in my testing, and it has been running without outage for over 96 hours.
I’ve since seen several other GB10 users report what appears to be the same behavior. I don’t want to claim that a GPU power spike is definitively the root cause. However, the following behavior was consistent:
Heavy GPU load / rapid GPU ramp → abrupt power-off, with nothing in the logs → GPU clock limited with nvidia-smi -lgc 300,2200 → stable
Hopefully this provides another data point for NVIDIA engineering when investigating the GB10 shutdown issue, and one from the HP ZGX Nano specifically.
You can adjust the fan curve or add additional fan to reduce temperature. Check how others did it. Many solutions are here and there. On mine I just improved the natural flow of air and I am using full clock speed with no software or hardware adjustment. I don’t think it will work for your spark because airflow is different from mine.
