I read a thread here recently that made me aware of a optimization that can be achieved with GB10’s but no-one seems to be talking about.
The post was about the tflop performance of the GB10 is so far more than the memory bandwidth and that the only way to utilize this bandwidth restriction is to have concurrent calls, i.e. the weights are loaded once and the tokens for multiple calls are generated at the same time. (I assume that the token cache would need to be reloaded per session?)
This opens the question to how to utilize this for coding tasks. It seems possible to run a swarm of coding agents that either
All work on the same problem at the same time and then the best solution is chosen.
Split the main coding task into multiple smaller concurrent tasks and run them at the same time.
I see no-one discussing this on these forums, and this may well be the way that the original GB10 designers intended the platform to be used for maximum performance.
It seems that the design of such a coding agent would not be mainstream but specialized for the GB10. I.e. to be able to split the main tasks into multiple smaller tasks. This is sort of happening with agents with sub-agents, but they are only launching 2 or 3 sub agents and not the 20 or so that would really move the needle. And secondly automatically being able to select the best coded solution from 20 solutions that each session has created, and maybe even merging the best of the bunch?
Has anyone actually got this working in practice and if so with which coding agent software?
I understand you only have one Spark, so I recommend a model that works well with tools. The one I’m sending you is from Qwen Code, so I recommend a Deepsek model (but you’ll need two Sparks for the v4 flash) or use Qwen models.
Interesting project. It looks similar to oh my open code. However if I understand it correctly, it looks like the agents are running primarily sequentially. There are some FE and BE agents running concurrently, but my experience with these kinds of agents is that only two or three get launched at any one time.
Because most agents are built to optimize for token usage, the design architecture is different. With the gb10 being able to run maybe 20 concurrent development tasks at no extra token costs. One can be very liberal in the token usage as long as it is for parallel tasks.
For e.g. you can give a coding problem to a lesser coding LLM, and it will solve the problem correctly let’s say 60% of the time. If we run 8 in parallel, that performance will jump to a 99.9% chance of solving the problem ( assuming the problem is in fact solvable by the LLM), and that we have to tools to select the correct solution.
I’ve seen alot of people talk about this, it’s all over the forums. The keywords are “concurrency” and “batching”. It’s just not that interesting to talk about, because it’s simple to implement. Your throughput goes down per stream when you do it, so it’s a bit painful for an agent you interact with if its part of the batch, but it’s great when you need to generate a ton of tokens. I use it for processing tons of air xiv papers into an information wiki, and also for some game development I’m doing where I’m using llm to play the opponent role. I can spin up a ton of test suites, and have the LLMs play both sides, very useful for my dev loop.
I use mainly opencode, it has extensive config to run sub-agents of any kind but the models usually not too keen to deploy subagents on their own - like to do everything themselves in one thread. However, yesterday I spent hours testing a new harness - jcode - which does automatically spawn subagents and is pretty insane. Still work in progress (judges, validators etc) but main functionality is solid and works. Rust-written, fast and light.
I have also looked at and failed to find something that does the swarm coding in the manner I am interested in using. So as most people on this forum do, I am building one and am getting close to something releasable. But it ended up being more than just a agentic coder, it ended up also being an opinionated agentic software development methodology with trackable requirements being built into stories that are then built by workers.
Have a look at the ideas at: www.swarmcoder.dev
Being a enterprise architect who messes with code, I have never had the time to learn multiple languages and so do almost all my development in Java. I also built this coder on my ZeroZ4j all java web development stack (interested java coders can look here: www.zeroz4j.com).
Hold thumbs I have the time to get the coder working soon.
This is definitely a prompting issue. As long as you define the circumstances in which subagents should be used, the criteria to judge based upon, and direct the orchestrator to use them whenever judgement allows for it, they will - in my experience. Also inspect the tool context for invoking a subagent as it may carry counterproductive instructions.
P.S. the ideal prompt design will of course vary by model ofttimes.
