GB10 / driver 580.159.03 - simultaneous dual DP-MST stream scanout fails (single stream works)
Hardware: ASUS Ascent GX10 (DGX Spark, GB10 Grace-Blackwell, aarch64)
OS: DGX OS (Ubuntu 24.04 base), DGX SWBUILD 7.2.3, all OTA/firmware fully applied (USB-C PD FW 0x507, EC, UEFI current)
Kernel: 6.17.0-1021-nvidia Driver: 580.159.03 (open) Session: X11 / GNOME (mutter 46)
Displays: 2x Lenovo P32p-20 (4K panels, tested at 2560x1440@59.95, 4K, and 720p)
Summary: A DP-MST hub connected to a USB-C port (DP 2.1 alt-mode, 20 Gbps) presents two MST sink streams (e.g. USB-C-1.1 and USB-C-1.2). Driving either stream alone works perfectly. Enabling both streams simultaneously blacks out both outputs - no scanout - even at 2x720p, which is far within the DP2.1 link budget. xrandr reports both connectors connected with valid modes, but neither produces an image when both are active. The blackout also occurs during early-boot GDM/GNOME automatic modeset, not just manual xrandr.
Steps to reproduce:
  1. Connect a DP-MST hub (2-stream) to a GX10 USB-C DP-alt port.
  2. Confirm a single stream drives one monitor correctly.
  3. Enable both MST streams (extend or mirror) → both outputs go black.
Ruled out:
  • Bandwidth - fails at 2x720p over a DP2.1 20 Gbps link.
  • Resolution/refresh - same at 1440p, 4K, and 720p.
  • Hub/cabling - confirmed NOT the dock: the same AV Access iDock C20, same USB-C cable, drives both monitors correctly when KVM-switched to a Windows PC. Only the GX10/GB10 host fails to scan out the second stream.
  • Compositor - reproduces under GNOME auto-modeset and manual xrandr alike.
Current workaround: one monitor on HDMI-0 (direct) + one via a single dock MST stream. Two simultaneous MST streams never scan out.
Question: Is simultaneous multi-stream DP-MST scanout supported on GB10 with the 580 open driver? Is this a known limitation/bug, and is a fix planned? nvidia-bug-report.sh attached.
nvidia-bug-report.log.gz (716.2 KB)
I’ve passed this along to our engineering team to investigate. I will respond once I hear something back
@thirt do you mind setting the nvidia_modeset.opportunistic_display_sync=0 kernel parameter? This could resolve the DP-MST light up issue.
@thirt Did you try setting the kernel parameter? Please let us know if you are still running into this issue
I got it to work on my system with some help :)
Confirming the opportunistic_display_sync=0 suggestion upthread — it works. Different hardware, same failure.
# /etc/modprobe.d/nvidia-modeset-opportunistic-sync.conf
options nvidia_modeset opportunistic_display_sync=0
then sudo update-initramfs -u and reboot.
With it set, two MST streams at matched 2560x1080 @ 59.978 Hz held a 30-minute soak, no drops. Without it, that same config never survived past 189 s on any stack I tried.
The tell: it depends on whether the two streams share a pixel clock, not on bandwidth.
Config Clocks Payload opp. sync Survived
2x 2560x1080 @ 59.98 matched 10.88 Gbps on 6–189 s — fails
2560x1080 @ 59.98 + @ 74.99 mismatched 12.29 Gbps on 1800 s — stable
2x 2560x1080 @ 59.978 matched 10.88 Gbps off 1800 s — stable
Note rows 1 and 2: the mismatched pair carries more data and survives. So it was never bandwidth or lanes — which matches your finding that it fails even at 2x 720p (720p on both is still matched, so it still triggers it).
Before finding the parameter, simply setting the two displays to different refresh rates was a full workaround.
Failure is non-deterministic — identical configs collapsed at 17 s, 29 s, 41 s, 149 s, 189 s. On collapse the whole connector drops (root + both branches), then re-probes at 1 Hz forever without recovering. No [drm] errors logged, in either KMS state.
Control: same dock, cables and panels run matched 2x 2560x1080 @ 60 Hz fine on a Dell Latitude 5410 (Intel iGPU, i915) under Fedora KDE. Different GPU vendor, driver and compositor — so the defect is in the NVIDIA display stack, not the dock, the panels, MST generally, or Wayland/GNOME.
System: DGX Spark GB10 · DGX OS 7.6.0 · kernel 7.0.0-1019-nvidia · driver 580.178.04 open · GNOME Wayland · nvidia-drm modeset=1 · EC firmware 0x03000508.
Dock: VVB USB-C dock (Amazon ASIN B0H2VKV1DQ), 2x HDMI via DP MST, not DisplayLink. Genesys Logic 05e3:0610 + 05e3:0625 hubs, ASIX 0b95:1790 GbE — all live on the same cable during the failure.
Panels: 2x LG ultrawide, GSM/0x76f9, native 2560x1080 @ 181.25 MHz.
Didn’t help: dock PD power, all four USB-C ports, EC firmware update, DGX OS 7.2.3→7.6.0, USB autosuspend off, custom CVT-RB modelines, staged low-then-high modesets.
Questions: Is opportunistic_display_sync meant to be safe with MST? If not, should it disable itself when an MST topology is present? And why does the failure take down the whole topology rather than one stream?
One aside for anyone here still on a stock image: mine shipped with nvidia-drm-options-modeset0 installed (modeset=0, overriding the driver’s modeset=1). Purging it raised survival 17 s → 149 s and re-enabled Wayland. It’s also reported to kill all display output after an OTA to DGX OS 7.5.0 — worth checking for.
