The Nemotron-Parse container does not appear to support the GB10 platform, as it is built for the ARM architecture.
You can run from sources:
git lfs install
git clone https://<username>:<token with write access>@huggingface.co/nvidia/NVIDIA-Nemotron-Parse-v1.1
cd NVIDIA-Nemotron-Parse-v1.1
uv venv --python 3.12 --seed
source .venv/bin/activate
uv pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu130
uv pip install "git+https://github.com/raphaelamorim/vllm.git@nemotron_parse"
uv pip install timm albumentations bs4 open_clip_torch
Create a file inference.py
from vllm import LLM, SamplingParams
from PIL import Image
sampling_params = SamplingParams(
temperature=0,
top_k=1,
repetition_penalty=1.1,
max_tokens=9000,
skip_special_tokens=False,
llm = LLM(
model="nvidia/NVIDIA-Nemotron-Parse-v1.1",
max_num_seqs=64,
limit_mm_per_prompt={"image": 1},
dtype="bfloat16",
trust_remote_code=True,
image = Image.open("./equation.png")
prompts = [
"prompt": "</s><s><predict_bbox><predict_classes><output_markdown>",
"multi_modal_data": {
"image": image
{ # Explicit encoder/decoder prompt
"encoder_prompt": {
"prompt": "",
"image": image
"decoder_prompt": "</s><s><predict_bbox><predict_classes><output_markdown>",
outputs = llm.generate(prompts, sampling_params)
for output in outputs:
prompt = output.prompt
generated_text = output.outputs[0].text
print(f"Decoder prompt: {prompt!r}, Generated text: {generated_text!r}")
run python inference.py, if everything is running fine is pretty straightforward to build a container image from it.
Thanks! I finally solved the problem using the steps below.
docker-compose.yml
services:
nemotron-parse2503:
container_name: nemotron-parse2503
working_dir: /app
ports:
- "8910:8000"
build: .
volumes:
- ${HOME}/.cache/huggingface/:/root/.cache/huggingface/
- ${HOME}/project/nemotron-parse:/app
environment:
- TZ=Asia/Taipei
gpus: all
ipc: host
ulimits:
memlock: -1
stack: 67108864
stdin_open: true
tty: true
command: bash
Dockerfile
FROM nvcr.io/nvidia/pytorch:25.03-py3
WORKDIR /app
COPY requirements.txt /tmp/requirements.txt
RUN pip install --upgrade pip \
&& pip install -r /tmp/requirements.txt
COPY . /app
requirements.txt
accelerate==1.12.0
albumentations==2.0.8
transformers==4.51.3
timm==1.0.22
