System: DGX Spark (GB10), DGX OS, kernel 6.17.0-1029-nvidia, driver 580.173.02, CUDA 13.0. Headless, runs one small CPU-heavy server process; GPU load is light.
Timeline (all Aug 12, EDT): In the morning I applied the July 2026 system update bundle (EC 0x02000b00, UEFI 4.0.0, driver 580.173.02). The machine had been stable for months before this (previous uptime streaks of 8+ days). Within hours of the update it spontaneously rebooted twice, at 14:06 and 16:06, almost exactly two hours apart, which makes me suspect something periodic rather than workload-triggered.
Crash 1 (14:06), end of that boot’s kernel log:
NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
NVRM: kgspHealthCheck_TU102: ********************************************
NVRM: _issueRpcAndWait: rpcRecvPoll failed with status 0x00000062 for fn 76 sequence 5742!
(earlier in the block: GSP “critical error 120”)
Crash 2 (16:06), the following boot died with a flood of repeated asserts (hundreds of lines over ~12 seconds, then reboot):
NVRM: nvAssertFailedNoLog: Assertion failed: (status == NV_OK) || (status == NV_ERR_GPU_IN_FULLCHIP_RESET) @ gpu_user_shared_data.c:373
Both boots ended in an unattended full system reboot. I have nvidia-bug-report-20260812.gz captured from the current boot, plus the full NVRM/GSP kernel log excerpts from both crashed boots, and have attached them.
nvidia-bug-report-20260812.gz (421.4 KB)
gpu-crash-1606.txt (595.8 KB)
gpu-crash-1406.txt (9.8 KB)
Watchdog is loaded and armed (sbsa_gwdt, action=1), so the reboots appear to be the watchdog firing after the GPU driver wedges, not a power or EC issue. The sbsa_gwdt blacklist issue from the older reboot threads does not apply here.
Possibly related to the Xid 119 GSP timeout reports on GB10; in my case the system self-reboots rather than wedging off the bus, and rpcRecvPoll fails with the same 0x62 status seen in the GSP init threads.
Questions: Is this a known regression in the July 2026 GB10 bundle / driver 580.173.02? Is there a recommended mitigation (driver hold/rollback) for a production box while it’s investigated?
