I am seeking help diagnosing recurrent GPU memory-subsystem/GSP timeouts on an ASUS GC34X RTX 5090 Laptop eGPU connected to a ROG Flow Z13. After the latest failure, the GPU reports reset required and no usable power, clock, temperature or utilization statistics. I have not established whether the cause is the NVIDIA driver/GSP, the USB4/PCIe path, firmware/hardware, or an application trigger.
Environment at capture
- Host: ASUS ROG Flow Z13 GZ302EA, AMD Strix Halo; BIOS GZ302EA.314 (DMI date 2026-07-20).
- CachyOS rolling, Linux 7.2.10-1-cachyos.
- External GPU: ASUS GC34X RTX 5090 Laptop GPU, 24,463 MiB; PCI 10de:2c18, subsystem 1043:225b.
- NVIDIA open kernel module and GSP: 615.78.08.
- Captured GPU VBIOS: 98.03.75.00.19; GC34X Thunderbolt NVM: 59.c2. I believe I already updated the VBIOS through Windows; the updater version/date and timing relative to this capture remain unconfirmed.
- Intel JHL9480 bridge 8086:5786 rev 85, AMD USB4 host routers 1022:158d/158e. USB4 reports 2 x 20 Gb/s lanes per direction; GPU endpoint reports PCIe 16 GT/s x4. These are link-state reports, not measured throughput.
- CUDA toolkit 13.4 / NVCC 13.4.92; GCC 16.2.1; CMake 4.4.4; Ninja 1.13.2.
- NInfer mobile fork Release/sm_120a, commit d0ae146f68815b59e2130d9fb3b521f7ccf89f1a; build succeeded.
- Model: Qwen3.8-27B QUASAR NVFP4, previously verified SHA-256 d196bf1d8294f1a684e01870967134eab59bec1692c61736f2452d9fa2d63594.
Failure on October 19
Times below are UTC+04:00. At 21:17:40, CUDA graph preparation in ninfer-serve failed with cudaErrorLaunchFailure at cudaStreamSynchronize and SIGABRT. Kernel Xid 13 reported a class/subchannel mismatch. Saved coredump metadata reaches NInfer cuda_check → DeviceContext::synchronize → ProgramImpl::prepare_graphs. This identifies where the asynchronous error was observed, not necessarily the originating operation.
A second launch with --no-cuda-graph reached ready at 21:20:39. A streamed chat request started at 21:22:14 and remained in prefill without an answer. At 21:23:30:
NVRM: GPU0 kgmmuInvalidateTlb_GM107: TLB invalidation failed waiting for completion (status=0x00000065)
NVRM: GPU0 kgmmuCheckMemSubsysError_IMPL: Memory Subsystem Error detected. kgmmuInvalidateTlb failed.
NVRM: Xid (PCI:0000:03:00): 175, pid=8485, name=ninfer-serve, GPU memory subsystem timeout (type 1) detected
NVRM: GPU0 _kgspLogGspTimeout: *** GSP Timeout: Memory subsystem error (origin=RPC) ***
At 21:23:33:
NVRM: Xid (PCI:0000:03:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (PF FLR)
At the approximately 21:40 diagnostic capture, nvidia-smi reports recovery action Reset and 20,862 MiB used of 24,463 MiB, although no active server/listener remains. The remaining ninfer-serve process is defunct. Power draw and usable limits/clocks/temperature/utilization are unavailable or reset-required. No conclusion about current power throttling can be drawn from these readings.
The graph-disabled attempt followed the Xid 13 failure in the same boot without verified GPU recovery, so this is not a controlled graphs-on versus graphs-off comparison.
Application command
Run from the NInfer repository; the pathname below is a placeholder for the same verified artifact:
./build/apps/ninfer-serve /path/to/qwen3_8_27b_quasar.ninfer \
--host 127.0.0.1 --port 8080 \
--max-context 262144 --kv-capacity auto --max-concurrency 1 \
--kv-dtype kvarn --spec mtp --draft-tokens 3 --lm-head-draft
The second attempt adds --no-cuda-graph. The failed request JSON and input token count were not preserved; server output records one streamed OpenAI chat message, default thinking and an 8192 output-token ceiling. The 262144 setting is capacity, not a measured 262144-token input. This is not yet a minimal CUDA reproducer independent of NInfer.
Earlier occurrence and separate performance symptom
The October 3 journal also contains Xid 175 / the same TLB invalidation failure and GSP memory-subsystem timeout, followed by Xid 154 PF FLR. That was driver 615.71.09, kernel 7.2.8-2-cachyos and NInfer commit 87f068980532480ba6f644d11058c9b815b73c4f. The CLI used FP8 KV, 32768 context, MTP3 and no-thinking; it stalled during loading. The error therefore predates the latest runtime update and current KVarN/262144 configuration.
Before that October 3 fault, a completed benchmark showed 180 MHz graphics/SM clock, mostly 100% utilization, P8/SW Power Cap and implausible reported draw of 432.99 W against a 150 W enforced limit. Those are historical readings; they are not available measurements of the October 19 fault. A bad power reading causing the low clock has not been established.
Related platform observations and reports
The host also has intermittent USB4/NVMe reconnect failures with a Corsair EX400U. A separate CachyOS report has been submitted and is pending moderation; no public topic URL is available yet.
During a physical hotplug session in the previous boot, the GPU root port logged link-down/card-not-present and Xid 79. Exact physical-action timing was not captured; I am not claiming that event was a spontaneous disconnection.
Related but not established duplicates:
- RTX 5080 via Thunderbolt 5 eGPU: Hard lock on CUDA operations (nvidia-smi works at idle) · Issue #979 · NVIDIA/open-gpu-kernel-modules · GitHub — external RTX 50-series CUDA hangs, including a GZ302EA/CachyOS comment with a different GPU/enclosure.
- [BUG] Thunderbolt 5 JHL9480 eGPU PCIe bridge becomes inaccessible on ASUS Flow Z13 GZ302EA / Strix Halo · Issue #1021 · CachyOS/linux-cachyos · GitHub — same host/JHL9480 family, different GPU/enclosure and failure details.
Diagnostic gaps and request
The official nvidia-bug-report.log.gz has not yet been collected. I have saved redacted kernel excerpts, the graph-abort stack, server transcript and topology/state captures, and can supply specific additional evidence. No GPU reset, driver/kernel/firmware modification, power/clock setting change or further CUDA workload was performed during this diagnostic. No vanilla-kernel comparison has been performed.
Please advise whether this matches a known external-Blackwell/GSP issue, which additional logs are most useful, and how to distinguish an application trigger from USB4/PCIe or GPU/driver failure. In particular, what evidence would help diagnose Xid 175 when the GPU remains reset-required and normal telemetry is unavailable?
FYI, the same setup (ninfer, same model, same device, same egpu) runs perfectly on windows.
