Gdb and Issac App - libsight_module.so: cannot open shared object
Following the '“Getting Started/Running an Application” documentation,
I tried to run the “gdb” and with the following command:
gdb --args bazel-bin/engine/alice/tools/main --app apps/tutorials/ping/ping.app.json
run
I am getting errors that “libping_components_module.so” and “libsight_module.so” can not be found.
My system is a “Ubuntu 18.04.3 LTS” on a PC with Isaac SDK 2019.3.
Issac SDK was build with “–strip=never --copt -g”
this is the console output:
`(gdb) run
Starting program: /home/myuser/.cache/bazel/_bazel_user/5313abd72d9e4c1e0501a91f4d0735c8/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/engine/alice/tools/main --app apps/tutorials/ping/ping.app.json
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
2020-03-18 11:00:51.581 INFO engine/alice/tools/websight.cpp@166: Loading websight…
2020-03-18 11:00:51.581 WARN engine/alice/backend/application_json_loader.cpp@171: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system’s abilities if possible.
2020-03-18 11:00:51.581 WARN engine/alice/backend/backend.cpp@183: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-03-18 11:00:51.581 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2020-03-18 11:00:51.581 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-03-18 11:00:51.581 INFO engine/gems/scheduler/scheduler.cpp@299: BlockerGroup: Cores = [9, 10, 11], Workers = No
2020-03-18 11:00:51.581 INFO engine/gems/scheduler/scheduler.cpp@299: WorkerGroup: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2020-03-18 11:00:51.582 ERROR engine/alice/backend/modules.cpp@250: apps/tutorials/ping/libping_components_module.so: /home/myuser/Dev/isaac//apps/tutorials/ping/libping_components_module.so: cannot open shared object file: No such file or directory
2020-03-18 11:00:51.582 ERROR engine/alice/backend/modules.cpp@250: packages/sight/libsight_module.so: /home/myuser/Dev/isaac//external/com_nvidia_isaac/packages/sight/libsight_module.so: cannot open shared object file: No such file or directory
2020-03-18 11:00:51.582 PANIC engine/alice/backend/modules.cpp@252: Could not load all required modules for application
Program received signal SIGABRT, Aborted.
__GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
51	../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb)`
