GDINO Docker container malfunctioning :: HTTP/1.1 500 Unexpected Error
System Information
  • Platform: Jetson AGX Orin
  • OS: Ubuntu 22.04.5 LTS
  • Kernel: Linux 5.15.148-tegra #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 aarch64
Container Version: nvcr.io/nvidia/jps/jps-gdino:ds7.1-public-12-11-1
Issue Description
Following the official NVIDIA tutorial for Grounding DINO on Jetson Platform Services, the container starts successfully but fails to process user-uploaded images with a GStreamer JPEG parsing error.
Error Message
ERROR from element jpegparse-000: Internal data stream error.
ERROR details ../libs/gst/base/gstbaseparse.c(3681): gst_base_parse_loop ():
/GstPipeline:gdino-pipeline/GstBin:source-bin-000/GstJpegParse:jpegparse-000:
streaming stopped, reason not-negotiated (-4)
Steps Followed (Exact Tutorial Implementation)
1. Container Setup
# Pull and run container as per tutorial
sudo docker pull nvcr.io/nvidia/jps/jps-gdino:ds7.1-public-12-11-1
sudo docker run -itd --runtime nvidia --network host nvcr.io/nvidia/jps/jps-gdino:ds7.1-public-12-11-1
Result: ✅ Container starts successfully
Starting inference server
INFO:     Started server process [670]
INFO:     Waiting for application startup.
INFO:     Application startup complete.
INFO:     Uvicorn running on http://0.0.0.0:8000 (Press CTRL+C to quit)
2. Image Upload
curl -X POST "http://localhost:8000/files" -H  "Content-Type: multipart/form-data" -F purpose="vision" -F media_type="image" -F "file=@hw2.jpg"
Result: ✅ Upload successful
{"id":"8a70d11f-a442-4880-a10d-8404ceebdc84","bytes":285417,"filename":"hw2.jpg","purpose":"vision","media_type":"image"}
3. Image Analysis Request
curl -X POST http://localhost:8000/inference -H "Content-Type: application/json" -d @highway.json
Result: ❌ FAILURE - Internal Server Error
  "code": "InternalServerError",
  "message": "Error in inference pipeline: {
    \"reason\" : \"ERROR from element jpegparse-000: Internal data stream error.
    streaming stopped, reason not-negotiated (-4)\",
    \"status\" : \"HTTP/1.1 500  Unexpected Error\"
Troubleshooting Attempts
Attempt 1: Image Format Analysis
Result: ✅ Image format is valid
hw2.jpg: JPEG image data, JFIF standard 1.01, aspect ratio, density 1x1, segment length 16, baseline, precision 8, 1280x720, components 3
Attempt 2: Image Conversion
curl -X POST "http://localhost:8000/files" -H  "Content-Type: multipart/form-data" -F purpose="vision" -F media_type="image" -F "file=@hw2_converted.jpg"
Result: ❌ Same error with converted image
Attempt 3: Simplified Prompt
Original prompt: "vehicle accident . vehicle crash . crash scene . vehicles colliding . accident involving vehicles . road accident . car . bus . person . bicycle"
Simplified prompt: "car, bus, person"
Result: ❌ Same error with simplified prompt
Attempt 4: Container Restart with Debug
sudo docker stop <container_id> && sudo docker rm <container_id>
sudo docker run -itd --runtime nvidia --network host -e GST_DEBUG=2 -v $(pwd):/workspace nvcr.io/nvidia/jps/jps-gdino:ds7.1-public-12-11-1
Result: ❌ Same error persists
Attempt 5: Alternative Container Version
sudo docker pull nvcr.io/nvidia/jps/jps-gdino:latest
Result: ❌ No latest tag available
Error response from daemon: manifest for nvcr.io/nvidia/jps/jps-gdino:latest not found: manifest unknown
Key Findings
1. Warmup Requests Work
The container successfully processes built-in test images during warmup:
  "choices": [{
    "message": {
      "content": {
        "boundingBoxes": [
            "bboxes": [[468, 1, 809, 721]],
            "confidence": [0.88079702854156494],
            "phrase": "bus"
        "frameHeight": 720,
        "frameWidth": 1280,
        "message": "person . bicycle . backpack . car . bus ."
  "usage": {"latency_in_ms": 1449}
2. User Images Always Fail
All user-uploaded images fail with the same JPEG parsing error, regardless of:
  • Image format (original vs converted)
  • Prompt complexity (complex vs simple)
  • Container restarts
  • Debug logging enabled
3. Container-Specific Issue
The error is consistent across:
  • Multiple container restarts
  • Different image files
  • Various prompt configurations
  • Fresh container instances
Root Cause Analysis
Based on the investigation, this appears to be a known issue with the specific GDINO container version ds7.1-public-12-11-1 related to:
  1. GStreamer Pipeline Configuration: The container’s GStreamer pipeline has compatibility issues with user-uploaded JPEG images
  2. JetPack 6.x Docker Issues: Known Docker networking and iptables problems in JetPack 6.x that affect container operations
  3. Image Processing Pipeline: The internal image processing pipeline expects specific image formats that differ from standard user uploads
Whats the solution?
Move to JPS forum.
Can your image decoded by gst command line? Can you share your image?
Yes the image is valid , here its attached
Can you have a try below command to convert the image before send the image to GDINO?
ffmpeg -i imput.jpeg -vf "format=yuv420p" -q:v 2 output.jpg
Yes with that conversion, now the GDINO service can correctly process the image and provide output. Should I do this for videos too?
Do you have any video meet issue? Please share the video if you meet any issue. We can have a check.
