Gdm causes the UI crash in ubuntu 18
Jetpack 4.6 jetson nano
Custom board
flashed the device → connected the ethernet to device with internet ->boots the board ->ssh is present ->UI is crashed caused by gdm
flashed the device ->connected ethernet without internet ->no issue with UI
flashed the device → didn’t connect the ethernet → no issue with Ui ->then connected ethernet with internet → then also no issue occured
please help me to get the root cause of this issue
and how can we fix this
dmesg_eth_connected.txt (61.2 KB)
var_log_issue_Xorg.0.log (15.2 KB)
This is the issue
the issue is with gdm which caused ui crash
As I already told in your post,
  1. Upgrade your BSP to jp4.6.4 and see if you can still see this issue.
  2. Try to reproduce your issue on NV devkit. If it can reproduce, share your steps.
We don’t know your board. jeptack4.6 is also too old to investigate.
If you want the help, do what I said first.
