Gdpr failed by 127.188.0.2:443 not connected
Really appreciate for helping me solved my question on GDPR https certification failed.
I think my omniverse-launcher worked well for several weeks.
but I now got another issue on gdpr which prevent me to install any apps. the launcher.log is below:
[2022-05-01 12:05:05.219] [info] Crash dumps directory: C:\Users\ouyang\AppData\Roaming\omniverse-launcher\Crashpad
[2022-05-01 12:05:05.280] [info] Omniverse Launcher 1.5.4 (production)
[2022-05-01 12:05:05.280] [info] Argv: C:\Users\ouyang\AppData\Local\Programs\omniverse-launcher\NVIDIA Omniverse Launcher.exe
[2022-05-01 12:05:05.319] [debug] Running “C:\omniverse\library\cache-2022.1.0\System Monitor\omni-system-monitor.exe”
[2022-05-01 12:05:05.325] [debug] Reset current installer.
[2022-05-01 12:05:05.620] [info] Logged in.
[2022-05-01 12:05:05.641] [info] Running production web server.
[2022-05-01 12:05:05.645] [info] HTTP endpoints listening at xxxx:33480
[2022-05-01 12:05:05.924] [info] Failed to get GDPR, retrying in 2.5 seconds…
[2022-05-01 12:05:05.940] [info] Failed to get EULA, retrying in 2.5 seconds…
[2022-05-01 12:05:07.668] [info] Failed to get EULA, retrying in 2.5 seconds…
[2022-05-01 12:05:08.738] [info] Failed to get GDPR, retrying in 2.5 seconds…
[2022-05-01 12:05:08.754] [info] Failed to get EULA, retrying in 2.5 seconds…
[2022-05-01 12:05:10.482] [info] Failed to get EULA, retrying in 2.5 seconds…
[2022-05-01 12:05:11.553] [error] FetchError: request to https://messages.launcher.omniverse.nvidia.com/en/gdpr.json failed, reason: connect ETIMEDOUT 127.188.0.2:443
at ClientRequest. (C:\Users\ouyang\AppData\Local\Programs\omniverse-launcher\resources\app.asar\dist\main.js:345:256056)
at ClientRequest.emit (node:events:390:28)
at TLSSocket.socketErrorListener (node:_http_client:447:9)
at TLSSocket.emit (node:events:390:28)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
Pls help me, thank you.
Hello @ouyangshixiong! Check out this forum post to see if this helps solve your issue: Omniverse - can't connect - gdpr.json failed
Yes, the forum post was very useful to me. I found the IP address of launcher-prod.s3.us-east-2.amazonaws.com on my local PC was different from the others in the forum post. So I fixed this issue by re-configure the DNS of my local network-proxy software.Now, it works :)
Thank you @WendyGram
