How do I activate GDS SCSI support?
OS and kernel:
Ubuntu 22.04.5 LTS
6.8.0-65-generic
I have three disks and four A100 with CUDA 13 and nvidia-open
lshw -class disk
*-disk:0
description: SCSI Disk
product: PERC H755 Front
vendor: DELL
physical id: 3.6c.0
bus info: scsi@0:3.108.0
logical name: /dev/sda
*-disk:1
vendor: DELL
physical id: 3.6d.0
bus info: scsi@0:3.109.0
logical name: /dev/sdb
*-disk:3
vendor: DELL
physical id: 3.6f.0
bus info: scsi@0:3.111.0
logical name: /dev/sdd
| NVIDIA-SMI 580.65.06 Driver Version: 580.65.06 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A100 80GB PCIe On | 00000000:17:00.0 Off | 0 |
| N/A 30C P0 53W / 300W | 4MiB / 81920MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA A100 80GB PCIe On | 00000000:65:00.0 Off | 0 |
| N/A 30C P0 54W / 300W | 4MiB / 81920MiB | 0% Default |
| | | Disabled |
| 2 NVIDIA A100 80GB PCIe On | 00000000:CA:00.0 Off | 0 |
| N/A 32C P0 75W / 300W | 1123MiB / 81920MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA A100 80GB PCIe On | 00000000:E3:00.0 Off | 0 |
| N/A 28C P0 53W / 300W | 4MiB / 81920MiB | 0% Default |
| | | Disabled |
nvidia-open/unknown,now 580.65.06-0ubuntu1 amd64 [installed]
nvidia-fs, nvidia-gds installed:
nvidia-fs/unknown,now 2.26.6-1 amd64 [installed]
nvidia-gds/unknown,now 13.0.0-1 amd64 [installed]
Output of GDScheck:
GDS release version: 1.15.0.42
nvidia_fs version: 2.26 libcufile version: 2.12
Platform: x86_64
ENVIRONMENT:
DRIVER CONFIGURATION:
NVMe P2PDMA : Unsupported
NVMe : Unsupported
NVMeOF : Unsupported
SCSI : Unsupported
ScaleFlux CSD : Unsupported
NVMesh : Unsupported
DDN EXAScaler : Unsupported
IBM Spectrum Scale : Unsupported
NFS : Unsupported
BeeGFS : Unsupported
ScaTeFS : Unsupported
WekaFS : Unsupported
Userspace RDMA : Unsupported
--Mellanox PeerDirect : Enabled
--rdma library : Not Loaded (libcufile_rdma.so)
--rdma devices : Not configured
--rdma_device_status : Up: 0 Down: 0
CUFILE CONFIGURATION:
properties.use_pci_p2pdma : false
properties.use_compat_mode : true
properties.force_compat_mode : false
properties.gds_rdma_write_support : true
properties.use_poll_mode : false
properties.poll_mode_max_size_kb : 4
properties.max_batch_io_size : 128
properties.max_batch_io_timeout_msecs : 5
properties.max_direct_io_size_kb : 16384
properties.max_device_cache_size_kb : 131072
properties.per_buffer_cache_size_kb : 1024
properties.max_device_pinned_mem_size_kb : 33554432
properties.posix_pool_slab_size_kb : 4 1024 16384
properties.posix_pool_slab_count : 128 64 64
properties.rdma_peer_affinity_policy : RoundRobin
properties.rdma_dynamic_routing : 0
fs.generic.posix_unaligned_writes : false
fs.lustre.posix_gds_min_kb: 0
fs.beegfs.posix_gds_min_kb: 0
fs.scatefs.posix_gds_min_kb: 0
fs.weka.rdma_write_support: false
fs.gpfs.gds_write_support: false
fs.gpfs.gds_async_support: true
profile.nvtx : false
profile.cufile_stats : 0
miscellaneous.api_check_aggressive : false
execution.max_io_threads : 4
execution.max_io_queue_depth : 128
execution.parallel_io : true
execution.min_io_threshold_size_kb : 8192
execution.max_request_parallelism : 4
properties.force_odirect_mode : false
properties.prefer_iouring : false
GPU INFO:
GPU index 0 NVIDIA A100 80GB PCIe bar:1 bar size (MiB):131072 supports GDS, IOMMU State: Disabled
GPU index 1 NVIDIA A100 80GB PCIe bar:1 bar size (MiB):131072 supports GDS, IOMMU State: Disabled
GPU index 2 NVIDIA A100 80GB PCIe bar:1 bar size (MiB):131072 supports GDS, IOMMU State: Disabled
GPU index 3 NVIDIA A100 80GB PCIe bar:1 bar size (MiB):131072 supports GDS, IOMMU State: Disabled
PLATFORM INFO:
IOMMU: disabled
Nvidia Driver Info Status: Supported(Nvidia Open Driver Installed)
Cuda Driver Version Installed: 13000
Platform: PowerEdge R750xa, Arch: x86_64(Linux 6.8.0-65-generic)
Platform verification succeeded
How do I activate the SCSI support?
