I have a GT218 [GeForce 310] card.
The latest driver on Nvidia site is 340.107
I am planning to move to RHEL 8.1 with current kernel 4.18.0-147
But the kernel driver module does not compile on this OS.
Is it possible to use my card with the above OS?
I contacted Nvidia support, they referred me to this forum.
thanks
Thomas Stephen Lee
Please use a repo driver like rpmfusion, those are patched to work with the rhel kernels.
340 is EOL by end of this year, btw.
rpmfusion also have stopped supporting, I guess.
http://download1.rpmfusion.org/nonfree/el/updates/8/x86_64/n/
I was looking for an update from Nvidia developers before the driver goes EOL.
thanks
Thomas Stephen Lee
lee.jnk
November 8, 2019, 10:53am
5
patch applied without errors.
and referred instructions at
to create installer.
successfully created a installer file.
but when running the patched installer,
failed at kernel module build step.
thanks
Thomas Stephen Lee
generix
November 8, 2019, 11:04am
6
What build errors are shown?
lee.jnk
November 10, 2019, 9:19am
9
please see updated error log after new patch.
http://bit.ly/nvidia-log
thanks
Thomas Stephen Lee
According to NVIDIA schedule, the 340xx driver is planned to be EOL by the end of the year.
Despite it works with the xorg-server version provided by RHEL up to 8.1, we (rpmfusion) don’t plan to introduce it for RHEL 8 and even newer Fedora.
That been said, if anyone volunteer to maintain this driver within the rpmfusion project by testing and collecting patches needed for the updated kernel, please do consider joining the efforts:
https://rpmfusion.org/Contributors
A more reliable alternative is to use nouveau instead for this hardware.
lee.jnk
November 22, 2019, 5:58am
11
Not prefect work around.
Install kernel-ml (5.3)
as per
and
install NVIDIA-Linux-x86_64-340.107-kernel-5.3-patched.run
from
Most installed apps seems working except vlc from RPM Fusion.
thanks
Thomas Stephen Lee
Please report the issue with vlc to bugzilla.rpmfusion.org as it’s working fine with most RHEL users.
You might have hit something specific to you.
An easier setup that wouldn’t requires any patching is to
Use the COPR repository kwizart/kernel-longterm-4.19 using:
dnf copr enable kwizart/kernel-longterm-4.19
dnf install kernel-longterm kernel-longterm-devel
And manually fetch the akmod-nvidia-340xx xorg-11-drv-nvidia-340xx from
http://download1.rpmfusion.org/nonfree/fedora/releases/30/Everything/x86_64/os/repoview/letter_a.group.html
http://download1.rpmfusion.org/nonfree/fedora/releases/30/Everything/x86_64/os/repoview/letter_x.group.html
Also the repo you are using will switch to a newer kernel version at some point and it will likely requires others patches. Best would be to switch to the 4.19 longterm kernel instead
lee.jnk
November 25, 2019, 7:59am
13
Reported bug to bugzilla.rpmfusion.
https://bugzilla.rpmfusion.org/show_bug.cgi?id=5472
thanks
Thomas Stephen Lee
lee.jnk
November 26, 2019, 8:37am
14
Tried installing on 5.4 kernel.
http://bit.ly/nvidia-log-5-4
fixes/patches anyone?
thanks
Thomas Stephen Lee
lee.jnk
November 26, 2019, 10:03am
15
Moved to this patched driver.
https://aur.archlinux.org/packages/nvidia-340xx/
VLC still not working though.
lee.jnk
November 26, 2019, 10:36am
16
vlc working after
yum reinstall ocl-icd
as per suggestion of rpmfusion maintainer.
lee.jnk
December 24, 2019, 4:38am
17
the new driver from Nvidia (340.108)
https://us.download.nvidia.com/XFree86/Linux-x86_64/340.108/NVIDIA-Linux-x86_64-340.108.run
works fine on RHEL 8.1 with the default Linux kernel (4.18.0-147.3.1)
thanks
Thomas Stephen Lee
hallo my Nvidia (340.108) not install
error
make -C /lib/modules/4.18.0-240.1.1.el8_3.x86_64/build KBUILD_SRC=/usr/src/kern$
-f /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/Makefile modules
make[3]: Entering directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( $
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.";
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are$
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it$
echo >&2 ;
/bin/false)
mkdir -p ./…/.tmp_versions ; rm -f ./…/.tmp_versions/*
make -f /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/scripts/Makefile.build obj$
/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/scripts/Makefile.build:45: /usr/sr$
make[4]: *** No rule to make target '/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_$
make[3]: *** [/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/Makefile:1544: _modu$
make[3]: Leaving directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
make[2]: *** [Makefile:157: sub-make] Error 2
make[2]: Leaving directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
NVIDIA: left KBUILD.
plese help me!!
