AFAIK this is maxwell as its a GM107 and maxwell has TMDS which can do 600 Mhz for HDMI 2.0 is that correct?
Can anyone from nvidia verify that this GPU is actually capable of this (hardware). I am curious if I can get 60Hz @ 4k out of this thing. I don’t care if it doesn’t have native BIOS/driver support as long as the hardware supports it.
The other new Maxwell GPUs are coming out as well (GTX 970/980). Please update your drivers so 600 Mhz pixelclock is capable. Would be nice for people to do 60Hz 4k via a modeline even if the full HDMI 2.0 spec is there. If the hardware is capable then it should be doable with a modeline.
I suspected this and the fact you can get 3 display ports on the 970/980 I went ahead and ordered a 980. I am hoping the linux support will be there but I have a feeling they did not implmeent HDMI 2.0 on linux and it will be limited to a 340 Mhz pixelclock :(
