Good morning developers,
Wish you are well and having a good day already. As a newbie to Nvidia and OpenGL/OpenCL development, I would like to request your expertise & insight.
I have inherited a prediction & analysis multithreaded application using:
- Java 1.8.0_162 (latest)
- Intel(R) Core™ i7-6700K CPU @ 4.00GHz #1
- 2 x GeForce GTX 1080 V411.63 (latest) or AMD RadeonHD6990s graphic cards
Testing
AMD cards and drivers
- Core i7-6700K CPU *** ONLY *** —> app succeeds.
- Using 1 or 2 RadeonHD6990 as additional computational resources —> app succeeds!
Nvidia cards and drivers
- Using 1 or 2 GeForce 1080 GTXs as additional computational resources —> driver fails!
- GTX driver crashes calling finishQueues & flushQueues with CL_INVALID_COMMAND_QUEUE.
- Driver crash causes JRE to crash.
- GTX driver recovers.
- Application requires a restart (expected).
I had others try in other environments:
- PCs WITHOUT Nvidia drivers —> app succeeds.
- PCs WITH Nvidia cards & drivers —> driver fails!
Nvidia support insists it is an application bug! I suspect it is a Nvidia driver issue as I CANNOT reproduce the crash when Nvidia is out of the picture!
Questions:
- Is anyone having a similar issue?
- What do the Gods of Graphics Computations recommend I try?
More info (snippet, will NOT execute):
try {
// eh: 09-21-18 debug
// com.jogamp.opencl.CLException$CLInvalidCommandQueueException: can not finish command queue [error: CL_INVALID_COMMAND_QUEUE]
Object future = commandQueuePool.invokeAll(taskList);
commandQueuePool.finishQueues();
commandQueuePool.flushQueues();
physicsEngine.writeMessage(“Found a total of " + numDirect + " direct contacts and " + numGap + " interactions”);
if(progressListener != null) progressListener.analysisComplete();
} catch (Exception e) {
e.printStackTrace();
The crash happens on commandQueuePool.finishQueues():
at com.jogamp.opencl.CLException.checkForError(CLException.java:73)
at com.jogamp.opencl.CLCommandQueue.finish(CLCommandQueue.java:1795)
at com.jogamp.opencl.util.concurrent.CLCommandQueuePool.finishQueues(CLCommandQueuePool.java:155)
at com.gcas.aces.analysis.GPUMeshAnalyzer.performNarrowPhaseProximityAnalysis(GPUMeshAnalyzer.java:163)
at com.gcas.aces.analysis.PhysicsEngine.computePartInteractions(PhysicsEngine.java:131)
at com.gcas.aces.gui.ACESMain$75.run(ACESMain.java:2218)
I am not a driver developer & this is the 1st time I am looking at CLCommandQueue.
Is this the correct/proper way to make these calls?
I cannot verify it searching online!
Happy today,
Eamen
