Hi everyone.
I recently bough a second hand Geforce GTX 750Ti.
I managed to get it working by using nouvaeu driver, however when I tried to use nvidia proprietary drivers it failed.
I am running Debian Testing/Buster and i tried the GPU on two different Towers one with a Xeon E3-1220 v5 and the other one with an i7-2600k).
I actually upgraded to Testing in order to try if updating the kernel would solve the issue, but it didn’t.
The two kernel versions are 5.4.0-4 for Testing and 4.19.0-8 for buster.
I tried both the drivers from the nvidia website and the ones packaged in debian (both the ones in buster-backports and the ones in buster).
In the end every attempt fail when the system (or me ) tries to load the nvidia kernel module.
The error is always No such device
Here is the output of modprobe nvidia_current -vv:
modprobe: INFO: ../libkmod/libkmod.c:365 kmod_set_log_fn() custom logging function 0x55b98e44c330 registered
install modprobe -i nvidia-current $CMDLINE_OPTS
modprobe: INFO: ../libkmod/libkmod.c:365 kmod_set_log_fn() custom logging function 0x55b6a8d7a330 registered
insmod /lib/modules/5.4.0-4-amd64/updates/dkms/nvidia-current.ko
modprobe: INFO: ../libkmod/libkmod-module.c:892 kmod_module_insert_module() Failed to insert module '/lib/modules /5.4.0-4-amd64/updates/dkms/nvidia-current.ko': No such device
modprobe: ERROR: could not insert 'nvidia_current': No such device
modprobe: INFO: ../libkmod/libkmod.c:332 kmod_unref() context 0x55b6a9858440 released
modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe -i nvidia- current ' for module nvidia: retcode 1
modprobe: ERROR: could not insert 'nvidia': Invalid argument
modprobe: INFO: ../libkmod/libkmod.c:332 kmod_unref() context 0x55b98f5c5430 released
This is the output of lspci -s 01:00 -vv :
0000:01:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation GM107 [GeForce GTX 750 Ti]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f4000000 (32-bit, non-prefetchable) [size=32M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=128M]
Region 3: Memory at e8000000 (64-bit, prefetchable) [size=64M]
Region 5: I/O ports at e000 [size=128]
Expansion ROM at f6000000 [disabled] [size=512K]
Capabilities: <access denied>
Kernel modules: nvidia
Following some hints online I tried adding this to my kernel parameters:
pcie_port_pm=off
without luck.
You can find the bug report attached.
nvidia-bug-report.log (475.1 KB)
Any hint?
Thanks, Gabriel
