Hi, I’ve tried searching and can’t find similar a topic to this. Hopefully someone can help.
I have a brand new laptop with GeForce RTX 3050 Ti running Mint 20.3 Cinnamon (although I have tried LMDE5 & Mint Mate 20.3 and seen the same issue).
I installed driver version 510.60.02 and it defaults to NIVIDIA on Demand mode. If I change it to NVIDIA Performance Mode and reboot the machine crashes immediately after the LUKS disk decryption password is entered. No messages displayed, black screen.
I can’t get out of it and the only thing I have been able to do to get past is to reboot and reinstall the OS.
Is there any way I can enable the Performance Mode without the system hanging on boot? Unfortunately I’m not sure how to get logs from the hung system.
I’ve tried to include as much info as possible. If anything else is needed I will provide also.
System Info:
System: Kernel: 5.13.0-40-generic x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 5.2.7
wm: muffin dm: LightDM Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine: Type: Laptop System: PC Specialist product: NP5x_NP7xHH_HJ_HK v: N/A serial:
Chassis: No Enclosure type: 10 serial:
Mobo: CLEVO model: NPxxHJ_HK_HH serial: UEFI: INSYDE v: 1.07.03TPCS
date: 07/02/2021
Battery: ID-1: BAT0 charge: 47.8 Wh condition: 47.8/48.3 Wh (99%) volts: 17.2/15.2
model: Notebook BAT serial: status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/235/317 serial:
charge: 100% (should be ignored) status: Discharging
CPU: Topology: 8-Core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP arch: N/A
L2 cache: 24.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 73728
Speed: 1423 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 4050 2: 1302 3: 3526
4: 3825 5: 4455 6: 3242 7: 800 8: 4500 9: 1674 10: 3339 11: 4525 12: 1479 13: 2616
14: 801 15: 1111 16: 1640
Graphics: Device-1: Intel vendor: CLEVO/KAPOK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:9a60
Device-2: NVIDIA vendor: CLEVO/KAPOK driver: nvidia v: 510.60.02 bus ID: 01:00.0
chip ID: 10de:25a0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1920x1080~144Hz
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.6
direct render: Yes
