We are working with a mipi Sony imx678 sensor on an 8GB Jetson Orin Nano, Jetpack 5.1.2.
It is streaming as expected both through v4l2-ctl and nvargus.
However we very sporadically get out of sync errors. This can happen after a days or even weeks of continuous stable streaming. Then we typically see this error occur multiple times in a short timeframe.
Nov 14 18:18:13 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=587648548768 sof_ts=587650154304 gerror_code=2 gerror_data=400060 notify_bits=0"
Nov 14 18:18:25 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=599208042944 sof_ts=599289721984 gerror_code=2 gerror_data=400060 notify_bits=40000002
Nov 14 18:18:40 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=614582652768 sof_ts=614584258272 gerror_code=2 gerror_data=400060 notify_bits=0"
Nov 14 18:19:00 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=633786070240 sof_ts=633787675744 gerror_code=2 gerror_data=400060 notify_bits=0"
Nov 14 18:20:09 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=702860874464 sof_ts=702862479968 gerror_code=2 gerror_data=400060 notify_bits=0"
Nov 15 05:33:33 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=41106272817248 sof_ts=41106274422784 gerror_code=2 gerror_data=400060 notify_bits=20000"
Nov 15 05:33:41 camco-tegra kernel: [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=41113861900768 sof_ts=41113863506304 gerror_code=2 gerror_data=400060 notify_bits=0"
We have seen this happen irrespective of the sensor modes, both 4-lane mipi @60 fps as 2-lane mipi @25fps.
Searching on the nvidia forum, for other people the errors start right away after the streaming start. Hence the new post.
Steps taken so far:
- Double checked the pix_clk_hz value.
- CAPTURE_TIMEOUT_MS is at 2500.
- I boosted the jetson clocks and will reply to this post to notify if it helped.
