General Omniverse Apps Launching Problem
I installed Windows 11 on Proxmox virtualization software.
I directed the video card to the client system as GPU Passthrough.
In general, the video card works fine, but all “omniverse” applications crash at startup.
Error code in Windows error reporting.
Faulting application name: kit.exe, version: 104.2.0.0, time stamp: 0x63fd3d84
Faulting module name: carb.profiler-cpu.plugin.dll, version: 129.11.0.0, time stamp: 0x63dd941f
Exception code: 0xc000001d
Fault offset: 0x0000000000019d82
Faulting process id: 0x0x38C
Faulting application start time: 0x0x1D9994A1E3CA769
Faulting application path: C:\Users\xxxxx\AppData\Local\ov\pkg\code-2022.3.3\kit\kit.exe
Faulting module path: c:\users\xxxxx\appdata\local\ov\pkg\code-2022.3.3\kit\kernel\plugins\carb.profiler-cpu.plugin.dll
Report Id: 6d882ec0-b657-429d-8da7-934162b543cb
Faulting package full name:
Faulting package-relative application ID:
When you delete the following 2 files from the relevant application, the application opens, but it gives the following error, what do these files do?
carb.profiler-gpu.plugin.dll
Then some Omniverse application closes itself after a certain period of time.
Errors When I Run Without Files
.\kit_windows\kit.exe ./composer/composer-standalone.kit --ext-folder composer --/plugins/carb.scripting-python.plugin/pythonPath=./registry/ --/exts/omni.ui/Window/enableDetach=false --allow-root
[Error] [carb] loadPlugin: Library path doesn't exist: c:/program files (x86)/nvidia corporation/graph composer/kit_windows/kernel/plugins/carb.profiler-cpu.plugin.dll
[Error] [omni.kit.app.plugin] Failed to load core plugin at: c:/program files (x86)/nvidia corporation/graph composer/kit_windows/kernel/plugins/carb.profiler-cpu.plugin.dll
[Warning] [omni.kit.app.plugin] Failed to load profiler: carb.profiler-cpu.plugin
[Error] [carb] loadPlugin: Library path doesn't exist: c:/program files (x86)/nvidia corporation/graph composer/kit_windows/kernel/plugins/carb.profiler-gpu.plugin.dll
[Error] [omni.kit.app.plugin] Failed to load core plugin at: c:/program files (x86)/nvidia corporation/graph composer/kit_windows/kernel/plugins/carb.profiler-gpu.plugin.dll
Loading user config located at: 'C:/Users/ugur/AppData/Local/ov/data/Kit/composer-standalone/2.5/user.config.json'
[Info] [carb] Logging to file: C:/Users/ugur/.nvidia-omniverse/logs/Kit/composer-standalone/2.5/kit_20230607_173056.log
2023-06-07 14:30:56 [2ms] [Warning] [omni.ext.plugin] [ext: omni_kit] Extensions config 'extension.toml' doesn't exist 'c:/program files (x86)/nvidia corporation/graph composer/composer/omni_kit' or 'c:/program files (x86)/nvidia corporation/graph composer/composer/omni_kit/config'
2023-06-07 14:30:56 [20ms] [Warning] [omni.ext.plugin] [ext: urls] Extensions config 'extension.toml' doesn't exist 'c:/program files (x86)/nvidia corporation/graph composer/kit_windows/exts/urls' or 'c:/program files (x86)/nvidia corporation/graph composer/kit_windows/exts/urls/config'
[0.098s] [ext: omni.stats-0.0.0] startup
[0.105s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.108s] [ext: omni.assets.plugins-0.0.0] startup
[0.111s] [ext: omni.gpu_foundation-0.0.0] startup
[0.125s] [ext: carb.windowing.plugins-1.0.0] startup
[0.134s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.98        | Graphics API: D3D12
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 4090          | Yes: 0 |     | 24156   MB | 10de      | a5a40000.. |
|     |                                  |        |     |            | 2684      | 0          |
| OS: Windows, Version: 10.0, Build: 22621
| Processor: Common KVM processor | Cores: 16 | Logical: 16
| Total Memory (MB): 16346 | Free Memory: 11821
| Total Page/Swap (MB): 19290 | Free Page/Swap: 12351
[0.271s] [ext: omni.kit.pipapi-0.0.0] startup
[0.276s] [ext: omni.kit.pip_archive-0.0.0] startup
2023-06-07 14:30:56 [262ms] [Warning] [omni.ext._impl._internal] There is already a module 'toml' in 'c:\program files (x86)\nvidia corporation\graph composer\kit_windows\python\lib\toml\__init__.py'. Can't import another module with the same name in public space from 'c:\program files (x86)\nvidia corporation\graph composer\kit_windows\extscore\omni.kit.pip_archive\pip_prebundle'.
[0.280s] [ext: omni.usd.config-1.0.0] startup
[0.286s] [ext: omni.usd.libs-1.0.0] startup
[0.416s] [ext: omni.kit.loop-default-0.1.1] startup
[0.417s] [ext: omni.kit.async_engine-0.0.0] startup
[0.418s] [ext: omni.kit.test-0.0.0] startup
[0.441s] [ext: omni.client-0.1.0] startup
[0.448s] [ext: omni.appwindow-1.0.1] startup
[0.451s] [ext: omni.kit.renderer.core-0.0.0] startup
[0.467s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.472s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[0.518s] [ext: carb.audio-0.1.0] startup
[0.519s] [ext: omni.ui-2.12.12] startup
[0.526s] [ext: omni.uiaudio-1.0.0] startup
[0.528s] [ext: omni.kit.mainwindow-1.0.0] startup
[0.530s] [ext: omni.kit.uiapp-0.0.0] startup
[0.530s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[0.546s] [ext: omni.usd.schema.anim-0.0.0] startup
[0.577s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[0.581s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.583s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.586s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[0.589s] [ext: omni.usd.schema.physics-0.0.0] startup
[0.593s] [ext: omni.usd.core-1.0.0] startup
[0.594s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.595s] [ext: omni.kit.actions.core-1.0.0] startup
[0.598s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[0.599s] [ext: omni.hydra.usdrt_delegate-4.0.6] startup
[0.603s] [ext: omni.timeline-1.0.5] startup
[0.605s] [ext: omni.kit.commands-1.4.5] startup
[0.609s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[0.610s] [ext: omni.usd-1.6.15] startup
[0.663s] [ext: omni.kit.collaboration.channel_manager-1.0.8] startup
[0.665s] [ext: omni.ui_query-1.1.1] startup
[0.665s] [ext: omni.kit.menu.utils-1.4.5] startup
[0.673s] [ext: omni.kit.usd.layers-2.0.7] startup
[0.678s] [ext: omni.kit.ui_test-1.2.9] startup
[0.680s] [ext: omni.kit.widget.path_field-2.0.3] startup
[0.682s] [ext: omni.kit.window.popup_dialog-2.0.10] startup
[0.685s] [ext: omni.kit.widget.browser_bar-2.0.3] startup
[0.695s] [ext: omni.kit.widget.filebrowser-2.3.4] startup
[0.698s] [ext: omni.kit.widget.nucleus_connector-1.0.1] startup
[0.699s] [ext: omni.iray.libs-0.0.0] startup
[0.714s] [ext: omni.kit.widget.versioning-1.3.8] startup
[0.716s] [ext: omni.kit.search_core-1.0.1] startup
[0.718s] [ext: omni.kit.notification_manager-1.0.4] startup
[0.720s] [ext: omni.mdl.neuraylib-0.1.0] startup
[0.722s] [ext: omni.kit.window.filepicker-2.6.8] startup
[0.749s] [ext: omni.mdl-0.1.0] startup
[0.760s] [ext: omni.kit.window.file_importer-1.0.6] startup
[0.761s] [ext: omni.kit.widget.graph-1.5.3] startup
[0.766s] [ext: omni.kit.material.library-1.3.20] startup
[0.768s] [ext: omni.kit.widget.searchfield-1.0.7] startup
[0.770s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[0.771s] [ext: omni.kit.context_menu-1.5.4] startup
[0.773s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[0.775s] [ext: omni.kit.window.property-1.8.2] startup
[0.777s] [ext: omni.kit.graph.delegate.modern-1.6.4] startup
[0.778s] [ext: omni.kit.widget.prompt-1.0.2] startup
[0.779s] [ext: omni.kit.window.title-1.1.2] startup
[0.780s] [ext: omni.kit.window.console-0.2.2] startup
[0.783s] [ext: omni.kit.documentation.builder-1.0.8] startup
[0.787s] [ext: omni.kit.widget.settings-1.0.1] startup
[0.788s] [ext: omni.exp.graph.core-1.4.3] startup
[0.792s] [ext: omni.exp.graph.composer-2.5.0] startup
[1.068s] [ext: composer-standalone-2.5.0] startup
[1.090s] app ready
