I need help please. I started to program a common brute forcer / password guesser with CUDA (2.3 / 3.0beta). I tried different ways to generate all possible plain text “candidates” of a defined ASCII char set.
In this sample code I want to generate all 74^4 possible combinations (and just output the result back to host/stdout)
$ ./combinations
Total number of combinations : 29986576
Maximum output length : 4
ASCII charset length : 74
ASCII charset : 0x30 - 0x7a
"0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxy"
CUDA code (compiled with 2.3 and 3.0b - sm_10) - combinaions.cu:
#include <stdio.h>
#include <cuda.h>
__device__ uchar4 charset_global = {0x30, 0x30, 0x30, 0x30};
__shared__ __device__ uchar4 charset[128];
__global__ void combo_kernel(uchar4 * result_d, unsigned int N)
int totalThreads = blockDim.x * gridDim.x;
int tasksPerThread = (N % totalThreads) == 0 ? N / totalThreads : N/totalThreads + 1;
int myThreadIdx = blockIdx.x * blockDim.x + threadIdx.x;
int endIdx = myThreadIdx + totalThreads * tasksPerThread;
if( endIdx > N) endIdx = N;
const unsigned int m = 74 + 0x30;
for(int idx = myThreadIdx; idx < endIdx; idx += totalThreads) {
charset[threadIdx.x].x = charset_global.x;
charset[threadIdx.x].y = charset_global.y;
charset[threadIdx.x].z = charset_global.z;
charset[threadIdx.x].w = charset_global.w;
__threadfence();
if(charset[threadIdx.x].x < m) {
charset[threadIdx.x].x++;
} else if(charset[threadIdx.x].y < m) {
charset[threadIdx.x].x = 0x30; // = 0
charset[threadIdx.x].y++;
} else if(charset[threadIdx.x].z < m) {
charset[threadIdx.x].y = 0x30; // = 0
charset[threadIdx.x].z++;
} else if(charset[threadIdx.x].w < m) {
charset[threadIdx.x].z = 0x30;
charset[threadIdx.x].w++;; // = 0
charset_global.x = charset[threadIdx.x].x;
charset_global.y = charset[threadIdx.x].y;
charset_global.z = charset[threadIdx.x].z;
charset_global.w = charset[threadIdx.x].w;
result_d[idx].x = charset_global.x;
result_d[idx].y = charset_global.y;
result_d[idx].z = charset_global.z;
result_d[idx].w = charset_global.w;
#define BLOCKS 65535
#define THREADS 128
int main(int argc, char **argv)
const int ascii_chars = 74;
const int max_len = 4;
const unsigned int N = pow((float)ascii_chars, max_len);
size_t size = N * sizeof(uchar4);
uchar4 *result_d, *result_h;
result_h = (uchar4 *)malloc(size );
cudaMalloc((void **)&result_d, size );
cudaMemset(result_d, 0, size);
printf("Total number of combinations\t: %d\n\n", N);
printf("Maximum output length\t: %d\n", max_len);
printf("ASCII charset length\t: %d\n\n", ascii_chars);
printf("ASCII charset\t: 0x30 - 0x%02x\n ", 0x30 + ascii_chars);
for(int i=0; i < ascii_chars; i++)
printf("%c",i + 0x30);
printf("\n\n");
combo_kernel <<< BLOCKS, THREADS >>> (result_d, N);
cudaThreadSynchronize();
printf("CUDA kernel done\n");
printf("hit key to continue...\n");
getchar();
cudaMemcpy(result_h, result_d, size, cudaMemcpyDeviceToHost);
for (unsigned int i=0; i<N; i++)
printf("result[%06u]\t%c%c%c%c\n",i, result_h[i].x, result_h[i].y, result_h[i].z, result_h[i].w);
free(result_h);
cudaFree(result_d);
The code should compile without any problems but the output is not what i expected.
On emulation mode:
CUDA kernel done hit key to continue...
result[000000] 1000
result[000128] 5000
On release mode:
result[000000] 1000
result[012288] 5000
if possible I want to generate everything inside of the kernel function . I also tried “pre” generating of possible plain text candidates inside host main function and memcpy to device, this works only with a very limited charset size (because of limited device memory).
any idea about the output, why the repeating (even with __threadfence() or __syncthreads()) ?
any other method to generate plain text (candidates) inside CUDA kernel fast :-) (~75^8) - maybe with “offset” constant values ?
thanks a million
