I’m using the GatorTron model from the UF NLP repository (UFNLP/gatortronS
) for a text generation task. I’ve successfully loaded the tokenizer and model and can tokenize the input prompt without issues. However, when I generate text using the model, the output is nearly identical to the input prompt, followed by repetitive padding (e.g., ....................................................................................................
). The generated token IDs also reflect this behavior, with a large number of repeated values.
Script:
from transformers import AutoTokenizer, AutoModelForCausalLM
Define a more detailed prompt to test
prompt = “What are the common symptoms associated with fever?”
Load the GatorTron base model tokenizer
tokenizer = AutoTokenizer.from_pretrained(‘UFNLP/gatortronS’)
print(“Tokenizer Loaded Successfully”)
Tokenize the input prompt
inputs = tokenizer(prompt, return_tensors=“pt”).input_ids
print(“Tokenized Inputs:”, inputs)
model = AutoModelForCausalLM.from_pretrained(‘UFNLP/gatortronS’, is_decoder=True)
print(“Model Loaded Successfully”)
Generate output using the model with adjusted parameters
outputs = model.generate(
input_ids=inputs,
max_new_tokens=100,
do_sample=True, # Enable sampling
top_p=0.9, # Use nucleus sampling
temperature=0.7 # Adjust temperature for diversity
print(“Generated Outputs (token IDs):”, outputs)
Decode the generated tokens to text
decoded_output = tokenizer.batch_decode(outputs, skip_special_tokens=True)
print(“Decoded Outputs:”, decoded_output)
Output:
Generated Outputs (token IDs): tensor([[ 101, 3810, 307, 134, 2813, 1111, 1551, 189, 1754, 574, 102, 112,
112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112,
112, 112, 112]])
Decoded Outputs: [‘what are the common symptoms associated with fever?..’]
The expected output should be a continuation of the input prompt with relevant content, but the model instead generates the same text as the input prompt, followed by a series of repetitive padding characters. I have tried adjusting the generation parameters (e.g., do_sample
, top_p
, temperature
), but the issue persists.
Has anyone encountered a similar issue, or can provide insights on how to resolve this?
