Is there any possibility to update the rt-tegra kernel (4.14.150-rt67-tegra) patch to generic ubuntu kernel, say version 5.4.0 ??
Or, is there any possibility to have generic Ubuntu 18.04 as one Guest OS?
There is one project requirement for me to have generic Ubuntu on Drive AGX. Please suggest.
Dear @satheesh90,
Is the ask is like you want to flash ubuntu OS onto DRIVE AGX? AFAIK, we do not support it. May I know why you are looking for this?
You do not need to use DRIVE OS in your project?
Hi @SivaRamaKrishnaNV , there is a requirement to have Kubernetes to scale and manage docker containers on drive-os . But, there are certain issues related to cgroup drivers in drive-os due to which the Kubernetes is failing. So, I thought of having a generic ubuntu on Drive AGX.
Dear @SivaRamaKrishnaNV , currently I’m trying to bring up the platform as per the project requirements. Once the platform is up and running, I’d use libs like CUDA and TensorRT for the applications.
Actually, I wanted to flash the generic Ubuntu as one Guest OS and the other guest OS be the Drive OS.
NVIDIA’s downstream kernel ships with a bunch of SoC-specific drivers and code. Unless you’re experienced in kernel development and willing to invest a few months you’re probably not going to be able to port that to anything newer.
You’d also have to carefully separate out the in-tree changes. Note essentially a tarball with no Git history is provided. Something I have done though for security update reasons.
