[genericReformat.cuh::copyPackedRunKernel::1487] Error Code 1: Cuda Runtime (invalid resource handle)
Description
When I use several models for tensorRT acceleration, when running together, this error is reported when one model is running, whether this is related to whether I load all models with the same class. Here are the classes I wrote:
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
# Simple helper data class that's a little nicer to use than a 2-tuple.
class HostDeviceMem(object):
    def __init__(self, host_mem, device_mem):
        self.host = host_mem
        self.device = device_mem
    def __str__(self):
        return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
    def __repr__(self):
        return self.__str__()
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
def allocate_buffers(engine, context):
    inputs = []
    outputs = []
    bindings = []
    stream = cuda.Stream()
    for i, binding in enumerate(engine):
        size = trt.volume(context.get_binding_shape(i))
        dtype = trt.nptype(engine.get_binding_dtype(binding))
        # Allocate host and device buffers
        host_mem = cuda.pagelocked_empty(size, dtype)
        device_mem = cuda.mem_alloc(host_mem.nbytes)
        # Append the device buffer to device bindings.
        bindings.append(int(device_mem))
        # Append to the appropriate list.
        if engine.binding_is_input(binding):
            inputs.append(HostDeviceMem(host_mem, device_mem))
        else:
            outputs.append(HostDeviceMem(host_mem, device_mem))
    return inputs, outputs, bindings, stream
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream, batch_size):
    # Transfer input data to the GPU.
    [cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
    # Run inference.
    context.execute_async(batch_size=batch_size, bindings=bindings, stream_handle=stream.handle)
    # Transfer predictions back from the GPU.
    [cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
    # Synchronize the stream
    stream.synchronize()
    # Return only the host outputs.
    return [out.host for out in outputs]
class TensorRTSession():
	def __init__(self, model_path):
		f = open(model_path, 'rb')
		runtime = trt.Runtime(TRT_LOGGER)
		trt.init_libnvinfer_plugins(TRT_LOGGER, '')
		self.engine = runtime.deserialize_cuda_engine(f.read())
		self.context = self.engine.create_execution_context()
		self.inputs_info = None
		self.outputs_info = None
		self.inputs, self.outputs, self.bindings, self.stream = allocate_buffers(self.engine, self.context)
	class nodes_info():
		def __init__(self, name, shape):
			self.name = name
			self.shape = shape
	def __call__(self, inputs):
		return self.update(inputs)
	def get_inputs(self):
		inputs_info = []
		for i, binding in enumerate(self.engine):
			if self.engine.binding_is_input(binding):
				shape = self.context.get_binding_shape(i)
				inputs_info.append(self.nodes_info(binding, shape))
				# print(binding, shape)
		self.inputs_info = inputs_info
		return inputs_info
	def get_outputs(self):
		outputs_info = []
			if not self.engine.binding_is_input(binding):
				outputs_info.append(self.nodes_info(binding, shape))
		self.outputs_info = outputs_info
		return outputs_info
	def update(self, input_arr, cuda_ctx=pycuda.autoinit.context):
		cuda_ctx.push()
		# Do inference
		for i in range(len(input_arr)):
			self.inputs[i].host = np.ascontiguousarray(input_arr[i])
		trt_outputs = do_inference(self.context, bindings=self.bindings, inputs=self.inputs, outputs=self.outputs,
								   stream=self.stream, batch_size=1)
		if cuda_ctx:
			cuda_ctx.pop()
		trt_outputs = trt_outputs[0].reshape(self.outputs_info[0].shape)
		return trt_outputs
Environment
**TensorRT Version8.6:
GPU Type:
Nvidia Driver Version: 515.43.04
CUDA Version: 11.7
