I am currently trying to get Gentoo to work on my Jetson TK1. However so far, I did not get a completely usable system.
Here is what I have tried so far:
Install u-boot and the system following http://elinux.org/Tegra/Mainline_SW/Gentoo_From_SD_Card.
-> No success. The board does not start, nothing is shown over UART. -
Modify the instructions at http://archlinuxarm.org/forum/viewtopic.php?f=49&t=7493 for installing a gentoo rootfs. I used a 3.17 and 3.17.1 mainline kernel.
-> System starts, I can log in, but I get strange graphics faults (normally works). Also most HW does not work (e.g. ethernet). Looks like PCIe support is still missing. -
Try to use the kernel sources from https://developer.nvidia.com/linux-tegra-rel-19 together with U-Boot and a gentoo rootfs.
-> Kernel wont start, last message on UART “starting linux kernel” or something similar.
From other postings I have gathered, that support for jetson-tk1 is still rudimentary in mainline. So this probably explains why PCIe does not work. So I should probably focus my efforts on the nvidia kernel.
However, what could be the reason why the kernel provided by nvidia does not work from u-boot? Looking through the kernel sources, I found that there are differnet device tree files for the nvidia kernel (tegra124-pm375) and the mainline one (tegra124-jetson-tk1). I tried to use both device trees, but I am not sure how to check in u-boot which DT was loaded.
Has anybody else had success starting the nvidia kernel from u-boot, or is there any other version of the kernel which has better HW support than the mainline one?
